lg m400dy frp not done lg m400dy frp not remove, yet software show done- Card found : 94FBD840 , v0136 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Device not found! Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Device not found! Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#0 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:14 |
ur phone is mtk6750, ver 7.0 yes , u can 100% done by Great Infinity . it's already done. thanks, mahir |
same problem Quote:
i have the same problem |
Welcome to Octoplus/Octopus Box LG Software version 2.9.3 -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM32 Selected baudrate: 0 Selected model: M400DY Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM32 Mode: Emergency Initializing flash...OK Model ID: LG-M400DY Platform: mt6750 Android version: 7.0 SW version: LGM400DYAT-00-V10h-AME-XX-MAR-14-2019+0 LAF Version: 1.1 Product ID: VS01S170926003656 IMEI: Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- IMEI A: 35xxxxxxxxxxxxxxxx IMEI B: 35xxxxxxxxxxxxxxxx Bluetooth address: 10:F1:F2:FD:F3:CE Wi-Fi MAC address: 10:F1:F2:77:44:72 SPC: 000000 -------------------------------------------------------------------------------- Detecting writing method... LAF Error: 80000121. Trying second method... Trying third method...Failed! Trying third method...Failed! Reset FRP operation for M400DY will delete all user data on the phone (contacts, pictures and others)! Do You want to continue? Resetting FRP Lock... Writing loader... LAF Error: 80000121. Trying second method...Failed! LAF Error: 0F0F0F0F. Reset FRP operation is currently not supported for your phone's firmware. Performed by 2.9.3 Software version. ---------------------------------------------------------------------------------- Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#0 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:08 what can i do???????????? |
Do not post logs from other boxes/dongles/softwares. You need to wait for update. Br. Infinity-Box Team. |
