04-09-2009, 08:26 | #1 (permalink) |
Junior Member Join Date: Jul 2007
Member: 549150 Status: Offline Thanks Meter: 3 | lg mg 110 infinity box can't repair imei COM3 [VCP0] selected module v1.38 Device: LG-MG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 011006003435876 current otp imei: 011284002610571 file saved: C:\Program Files\InfinityBox\LGA\eeprom_011006003435876_LG-MG110_20090409-012022.B1E.bin ........ version: 722-07V10a54MG110aP40FL Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 64 sec Remove/Install battery now ! is there anyway to fix this phone with infinity? |
04-09-2009, 16:48 | #3 (permalink) |
Member: 549150 Status: Offline Thanks Meter: 3 | imei still at 00000 COM3 [VCP0] selected module v1.38 Device: LG-MG110 Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 011006003435876 current otp imei: 011284002610571 file saved: C:\Program Files\InfinityBox\LGA\eeprom_011006003435876_LG-MG110_20090409-093810.B1E.bin ........ version: 722-07V10a54MG110aP40FL Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: 01227E22212200:FEEA0000000000 Write Done Finished, time used: 78 sec Remove/Install battery now ! COM3 [VCP0] selected module v1.38 Device: LG-MG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 353329013069824 current otp imei: 011284002610571 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353329013069824_LG-MG110_20090409-093959.B1E.bin ........ version: 722-07V10a54MG110aP40FL Check flash Done Check space ... current eeprom imei: 353329013069824 ............... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 65 sec Remove/Install battery now ! |
I Can't repair IMEI of LG KP107 | BackSlash_cu | Z3X-Team Products | 1 | 01-10-2010 20:08 |
I Can't repair IMEI of LG KP107 [SOLVED] | BackSlash_cu | PolarBox 3 | 6 | 01-10-2010 08:46 |
LG Sgold3 Tool Update. ver:2.2.066 can't repair imei | raulka2003 | Z3X-Team Products | 2 | 12-15-2009 00:06 |
infinity box not repair imei funtion not in modulo? | landk | Infinity-Box | 2 | 11-21-2008 15:37 |
is possible change imei for lg ke970 with infinity box? I am waiting ur helps.. | islam01 | Infinity-Box | 4 | 08-20-2008 16:38 |
