08-27-2011, 13:46 | #1 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | LG S310 after unlock rebooting i did read codes after that phone begin rebooting i downloaded flash file and flash it now its dead please help ==== [27.08.2011 16:56:56] ==== COM3 [VCP0] selected module v4.01 Action: "user code" unlock method: smart fast Model: LG-GS310 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: MAUI.09AW0944LGE_WISE_SP.W10.32 Version: ROSEMARY_HW 115 byte(s) read connection Ok 217 byte(s) read reading data... reading data #2... building new data... writing data... user code set to: 0000 Finished, time used: 51 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [27.08.2011 16:58:56] ==== COM3 [VCP0] selected module v4.01 Device: LG-GS310 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0008]: 00EC:00B100000055 [SAMSUNG] K9F1G16Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (460800)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 01800000/06800000 firmware size: 24Mb ffs size: 104Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.09AW0944LGE_WISE_SP.W10.32 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: A94810B5 bootloader version: ROSEMARY_BOOTLOADER_V005_MT6235B_MAUI_09AW0944LGE_ WISE_SP_W10_32 nfi area detection (2 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW0944LGE_W ISE_SP_W10_32.BIN project-id: MAUI.09AW0944LGE_WISE_SP.W10.32, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done Finished, time used: 2 min 4 sec Remove/Install battery now ! COM3 [VCP0] selected module v4.01 Device: LG-GS310 Checking data, wait... Action: write flash NAND write: Firmware S310_ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW0944 LGE_WISE_SP_W10_32_2010-11-24.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: A94810B5 bootloader version: ROSEMARY_BOOTLOADER_V005_MT6235B_MAUI_09AW0944LGE_ WISE_SP_W10_32 nfi area detection (2 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0008]: 00EC:00B100000055 [SAMSUNG] K9F1G16Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (230400)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 01800000/06800000 firmware size: 24Mb ffs size: 104Mb detect sec ro... detect custom parameters... detect project-id... project-id: MAUI.09AW0944LGE_WISE_SP.W10.32 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... incorrect ext bootloader signature: A94810B5 bootloader version: ROSEMARY_BOOTLOADER_V005_MT6235B_MAUI_09AW0944LGE_ WISE_SP_W10_32 nfi area detection (2 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW0944LGE_W ISE_SP_W10_32.BIN project-id: MAUI.09AW0944LGE_WISE_SP.W10.32, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... incorrect ext bootloader signature: A94810B5 bootloader version: ROSEMARY_BOOTLOADER_V005_MT6235B_MAUI_09AW0944LGE_ WISE_SP_W10_32 nfi area detection (2 cores) finished: Ok startup code area #1 check... done number of cores: 2 loading files... number of areas: 2 done write... write bootloader... . . . . . . write core... Disconnect... done Finished, time used: 13 min 22 sec Remove/Install battery now ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
