lg s310 unloking problem plz help>>>>>>>>>>>>>>>>> COM25 [VCP0] selected module v3.92 Action: read unlock codes unlock method: read codes Model: LG-GS310 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: MAUI.09AW0944LGE_WISE_SP.W10.32 Version: ROSEMARY_HW 115 byte(s) read connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 205 byte(s) read reading data... 188 byte(s) read lock[1] code: - default lock[2] code: - default lock[3] code: - 1122 lock[4] code: - default lock[5] code: - default lock[6] code: - default lock[7] code: - default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 11 sec Remove/Install battery now ! where is the unlok code??? thanx AK' |
Here is Ur information Phone code: 1122 Or Sim Lock Code Read Care fully if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Br, .::Dr.Gsm::. |
bro i wana unlock..... i did try this.. if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again but with out remove betrry it cannot connect.... this fone dont connect whith power button then i did connect cable then press sp unlok then insert bettry then fone will connect automatically.... i have tried with gs102 cable.....is there any other cable then tell me plz.. plz help meee thanx AK' |
ive got exatcly the same problem... please help!! wish to find a solution! Quote:
Action: read unlock codes only cood telphone no read cood nsk sp-unloking |
- power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 11 sec Remove/Install battery now ! read unlock codes again |
done but think my counter is blocked?! |
phone does not ask for any code, so when e put 1234568 nothing happens!!!! i guess direct unlock should be implemented! thx. |
if not then complete flash and also write eeprom And Post Result BR, .::DR.Gsm::. |
