11-18-2008, 09:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: United Kingdom
Member: 621787 Status: Offline Thanks Meter: 142 | i unlock kp130 COM4 [VCP0] selected module v1.54 Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set baud ... 115200 Set baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: ULC2GL 2008-03-06 1.0 TMO_UK KP100 01 FL 44 V10a 234-30 MAR-0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sta_20081118-114816.B1E.bin loading data... data loaded imei: 3584790208********** reading eeprom-sec_358479020869*******. file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-sec_358479020860*******_00000000-11008.B1E.bin reading eeprom-complete_35847902086915600... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35847902086*****_000000-110000.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 79974873 Finished, time used: 36 sec Remove/Install battery now ! |
The Following User Says Thank You to abid dar For This Useful Post: |
11-18-2008, 16:05 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
how to unlock KP130 | leroi | Infinity-Box | 19 | 03-08-2009 22:10 |
How To Unlock Kp130 With Fg | sairat | FuriousGold | 12 | 08-07-2008 09:53 |
Successfully Flashed & Unlocked Kp130 | mujahid_ali | Infinity-Box | 11 | 05-26-2008 16:27 |
Thanks Multi Box Team Unlock Kp130 | sarfraz | Multi-Box | 1 | 04-19-2008 16:26 |
unlock KP130??? | roverboc | VygisToolbox | 1 | 04-14-2008 12:06 |
