Old 03-29-2017, 08:32   #1 (permalink)
sidramobilecare's Avatar
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
intex aqua y4 dead
intex aqua y4 dead
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 45010053454D3034473A0D77B7625265
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0xBE0B0000
EMICFG_RET_FAILED
CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED
Boot Error!
Operation Failed
Elapsed: 00:01:06
Reconnect Power/Cable!
CM2 team
what does it mean, where is the problem ?
Old 03-29-2017, 08:34   #2 (permalink)
Member: 584794
Thanks Meter: 24
Originally Posted by sidramobilecare View Post
intex aqua y4 dead
CM2 team
I think it's emmc problem
Sent from my ONEPLUS A3003 using Tapatalk
The Following User Says Thank You to MUNNAMOBILES For This Useful Post:
Old 03-29-2017, 10:09   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make sure you had selected CORRECT firmware for your HW revision.
If you had try all of them and SAME error - then it mean eMMC or DRAM problem ( if DRAM separate IC - need chnage it, if eMCP - need change it , or atleast - resolder )
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.16929 seconds with 8 queries
