06-08-2009, 11:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 618439 Status: Offline Thanks Meter: 9 | lgkg220 flash problum Device: LG-KG220 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 359101006189461 file saved: C:\Program Files\InfinityBox\LGA\eeprom_359101006189461_LG-KG220_20090608-031827.B1E.bin ...... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881500010001:89881500000000 flash: 90009000000000:90909000000000 flash: 90009000000000:90909000000000 flash: 89881500010001:89881500000000 write: 2nd chip area error: no any expected answer error: flash write error: 18000000:00002000 error: no any expected answer error: flash write error: 18000000:00002000 helpe me infinity teem |
06-08-2009, 13:22 | #3 (permalink) |
Member: 618439 Status: Offline Thanks Meter: 9 | COM4 [VCP1] selected module v1.38 Device: LG-KG220 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb id: 00005258 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 359101006189461 file saved: C:\Program Files\InfinityBox\LGA\eeprom_359101006189461_LG-KG220_20090608-051632.B1E.bin ...... reading _eeprom-ffs_359101006189461... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_359101006189461_LG-KG220_20090608-051936.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... error: no any expected answer error: flash erase error: 18400000 error: no any expected answer error: erase #E2 Erase Fail Finished, time used: 231 sec Remove/Install battery now ! |
L6 Flashing Problum | aukonline | Smart-Clip | 1 | 07-29-2006 18:29 |
NGAGE QD flashing problum | ashrafcell | Nokia Hardware & Hardware Repair | 2 | 07-01-2006 09:03 |
nokia 6600 flashing problum | whitwline_mc | WD2 & APE (Symbian Phones) | 5 | 06-14-2006 14:25 |
nokia 6600 flashing problum | whitwline_mc | WD2 & APE (Symbian Phones) | 4 | 06-08-2006 03:49 |
flashing problum | irfanb20 | Wallpaper, Applications, RingTones, etc | 1 | 04-13-2006 02:15 |
