07-16-2008, 15:11 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: pakistan Age: 38
Member: 95385 Status: Offline Thanks Meter: 6 | lobster 575 unlock problem Device: Lobster 575 Checking data, wait... Action: read eeprom Boot... Phone should be Switched OFF ! Press Power button now ! boot version: connecting... error: can't run bootcode error: boot error[04] Boot Fail Finished, time used: 10 sec Remove/Install battery now ! sir give this error ..what problem ..cables ok |
09-03-2008, 00:22 | #3 (permalink) | |
Freak Poster Join Date: Apr 2006
Member: 256010 Status: Offline Thanks Meter: 11 | lobster 575 Quote:
i did unlock to many them no problem i have this lobster 575 keep[ given this eror can you tell me what i do wrong COM17 [VCP0] selected Device: Lobster-575 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 20 sec Remove/Install battery now ! i triyed com 1 as well | |
09-03-2008, 18:07 | #5 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: United kingdom Age: 64
Member: 26440 Status: Offline Thanks Meter: 6 | Quote:
COM13 [VCP0] selected Device: Lobster-575 Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 47 sec Remove/Install battery now ! | |
09-03-2008, 18:58 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Be sure that you have used latest HModule software. Also it may be problem with cable. If old pinout is not works you can try to use other pinout: keyboard top 1.........24 13: Phone Tx (RJ45 pin-3) 14: Phone Rx (RJ45 pin-2) 24: Gnd 17: Phone Tx (RJ45 pin-3) 18: Phone Rx (RJ45 pin-2) 24: Gnd |
04-07-2009, 18:43 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | i am face always face this message, try many times same result.. COM5 [VCP0] selected module v1.32 Device: Lobster-575 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! boot version: connecting... error: can't run bootcode Boot fail error: operation failed Finished, time used: 90 sec Remove/Install battery now ! |
04-07-2009, 18:44 | #8 (permalink) |
Member: 52828 Status: Offline Sonork: KHADIM100 Thanks Meter: 1,212 | try with Lobster 485, but not success. COM5 [VCP0] selected Device: Lobster 485 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... file saved: C:\Program Files\InfinityBox\VModule\backup_eeprom_20090407-153700.4DE.bin Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0001:227E22022201 Writing Done Finished, time used: 23 sec Remove/Install battery now ! |
04-07-2009, 19:34 | #9 (permalink) | |
http://forum.gsmhosting.com/vbb/show...30&postcount=6 | |
04-07-2009, 21:38 | #12 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | this may help you.http://forum.gsmhosting.com/vbb/showthread.php?t=612167 |
04-07-2009, 21:39 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is information about two types of pinout: http://forum.gsmhosting.com/vbb/show...30&postcount=6 |
Problem to unlock a Lobster 575? | The Repair Shop | Infinity-Box | 7 | 10-22-2007 15:11 |
Lcd problem ona Lobster 575 after unlock? | The Repair Shop | Infinity-Box | 2 | 06-08-2007 08:36 |
Lobster 575 Unlock Cable | Nasmi | VygisToolbox | 8 | 09-03-2006 08:59 |
FIRST !!! LOBSTER 575 UNLOCK CLIP by Phoneunlock.com | datacablelondon | Main Sales Section | 0 | 07-05-2006 12:35 |
lobster 485 unlock problems | NUNO_GSM | Various | 1 | 05-18-2006 11:10 |
