07-10-2018, 18:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Algéria
Member: 484595 Status: Offline Thanks Meter: 39 | Logikids 3 rk3126c not remove frp cm2 rkt 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] Machine : RK312X Device : RK3126C ExtInfo : 7.0.0 SoC CPU : 312A Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8,25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Remove FRP 0 ... Failed to remove FRP! Wiping UserData ... Failed to wipe DATA! Done! Elapsed: 00:00:10 |
07-10-2018, 19:12 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, It's loader is protected for now limited operations supported,,team is working on it Sent from my S_plus using Tapatalk |
The Following User Says Thank You to princesaddam For This Useful Post: |
