Lot of Gradiente gf760 problem... Hi i have loses a lot of gradiente gf760 cannot conect.... This is a new chipset?? help me infinty team...fix this please!! COM4 [VCP0] selected Device: Gradiente GF760 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: B510:48EA:2280:5014 error: unknown flash chip: 6646:2373:FFFF:FFFF Check Space Fail Finished, time used: 15 sec Remove/Install battery now ! |
Hello, Please, download and install lates HModule from Infinity-Box support area, use HModule instead of old software. |
Thx u...but still cant boot phones...... PS= V-power cant conect too....i think really theses phones are new chipset.... HMmodule 1.21 COM4 [VCP0] selected Device: Gradiente-GF760 Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 20 sec Remove/Install battery now ! :( |
hold power key till the end of the full processes... Even in flashing |
Your phone powers up normaly?? If not maybe it have a hw problem... |
VPower uses other cable,not same like Infinity. Regards,Vygis |
Someones i can unlock w/o problems... Someones impossible |
I`ve used all v-power cable in infinity and vise-versa no problems..... Anyway i will check this..... thx mr. vygis!!! |
It\'s interesting to see cables difference for me too. Please somebody post here another pinout for this phone, not the same like yuou can see in Infinity-Box Shell. |
AIKO 52G,GRADIENTE GF760,GRADIENTE GC-300,GPRS 779 PINOUT : KEYBOARD I------------------------I 24 1 1,2 - GND 7 - RX (data from PC) 8 - TX (data to PC) LG7050 24 pins connector |
It's the same hust the pin cont is in reverse!! :D:D Here is infinity pinout... Cable name: Lobster-575 keyboard top 1.........24 13: Phone Tx 14: Phone Rx 24: Gnd |
It's not same-try calculate pins again :) Regards,Vygis |
Really pinout is not same. Tested v-power pinout can be used in both boxes in some gf760 versions. Tested infinity pinout can be used in both boxes in some gf760 versions. But has some versions that just infinity pinout and Hmmodule 1.21 can boot....after unlock infinity says: phone unlocked ok but phone still locked....after tryes no sucess ....did i full flash back-up and flash phone with infinity support area files. Result= PHONE DEAD Infinity cant write back-up in phone, what i do?? i need to send backup to infinity support?? Here my first log after change cable to infinity pinout. Loading data, wait... [Infinity Box] v1.21 Current model: Gradiente-GF760 COM4 [VCP0] selected Device: Gradiente-GF760 Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot done Check connection... Check connection done Set baud... 812500 Set baud done Check hardware... flash: 01227E223C2200:8AEA0000000000 flash: Amd PL256N D 16Mb Check hardware done Read data... reading Gradiente-GF760_eeprom_calibration-1... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_Gradiente-GF760_eeprom_calibration-1_20080705-132042.92E.bin reading Gradiente-GF760_eeprom_calibration-2... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_Gradiente-GF760_eeprom_calibration-2_20080705-132503.92E.bin Read data done Check data... file saved: C:\Arquivos de programas\InfinityBox\HModule\backup_eeprom_200807 05-132915.92E.bin please, wait... pass-1... pass-2... pass-3... pass-4... pass-5... pass-6... pass-7... pass-8... Check data done Writing... flash: 01227E223C2200:46237300000000 Write: eeprom Writing done Finished, time used: 635 sec |
Hello, 1. send flash backup from locked phone to [email protected] and include some info what was the reason to send files 2. go to software \"settings\" page, make \"Advanced chip detection\" box checked and flash phone again |
