12-11-2016, 12:57 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: india
Member: 1755126 Status: Offline Thanks Meter: 42 | lyf ls-4006 sc9830 emmc boot faild... Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC Generic Loader v2 Inf Sending FLASH FDL Boot failed! Boot failed! Reconnect Power/Cable! |
12-11-2016, 14:08 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try with/without ALTLDR mode as well. Also in few cases need to press volume key (up or down or both)to boot phone. Br. Infinity Box Support Team. |
12-12-2016, 15:56 | #6 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | i have sc9830 google lock problem device info: Code: platform: sc8830, cpu abi: armeabi-v7a manufacturer: ADVAN hardware: sc9830 board: chinapalms_4m_oversea, name: chinapalms_4m_oversea brand: ADVAN, model: i5C build id: LMY47D, version: 5.1 Lollipop (i5C_LF5029_V2_20160830) build date: Tue Aug 30 20:05:04 CST 2016, security patch: 2016-02-01 build description: i5C_LF5029_V2_20160830 soc: sc9830 memory: 1 GB boot serial no: Z2010V20816UG039046 serial no: Z2010V20816UG039046 baseband version: FM_BASE_15B_Release_W16.14.6_P2|sc9830_modem|04-28-2016 11:52:05 ril version: android reference-ril 1.0 sim state: ABSENT,NOT_READY sim operator: 3() network type: HSPA,Unknown signal strength: 0 dBm (99 asu) (no service) signal strength: 0 dBm (99 asu) (no service) android_id: 8982e057ff0e8d45 bt addr: wifi mac: country: ID language: in battery level: 77% superuser: no Rebooting to bootloader... Done. Waiting for fastboot to be ready... failed Operation aborted by user request. platform: sc8830, cpu abi: armeabi-v7a manufacturer: ADVAN hardware: sc9830 board: chinapalms_4m_oversea, name: chinapalms_4m_oversea brand: ADVAN, model: i5C build id: LMY47D, version: 5.1 Lollipop (i5C_LF5029_V2_20160830) build date: Tue Aug 30 20:05:04 CST 2016, security patch: 2016-02-01 build description: i5C_LF5029_V2_20160830 soc: sc9830 memory: 1 GB boot serial no: Z2010V20816UG039046 serial no: Z2010V20816UG039046 baseband version: FM_BASE_15B_Release_W16.14.6_P2|sc9830_modem|04-28-2016 11:52:05 ril version: android reference-ril 1.0 sim state: ABSENT,NOT_READY sim operator: 3() network type: HSPA,Unknown signal strength: 0 dBm (99 asu) (no service) signal strength: 0 dBm (99 asu) (no service) android_id: 8982e057ff0e8d45 bt addr: 00:27:15:08:78:df wifi mac: country: ID language: in battery level: 77% superuser: no Card/BGA: BGA (Discrete embedded) Manufacturer ID: 0x70 (Kingston) Product name: V10008 (0x563130303038), rev: 0x50, serial number: 0x26E8ED27 Manufacturing date: Mar 2000 CID: 70010056 31303030 385026E8 ED273300 CSD: D04F0132 0F5903FF FFFFFFEF 8A400000 platform: sc8830, cpu abi: armeabi-v7a manufacturer: ADVAN hardware: sc9830 board: chinapalms_4m_oversea, name: chinapalms_4m_oversea brand: ADVAN, model: i5C build id: LMY47D, version: 5.1 Lollipop (i5C_LF5029_V2_20160830) build date: Tue Aug 30 20:05:04 CST 2016, security patch: 2016-02-01 build description: i5C_LF5029_V2_20160830 soc: sc9830 memory: 1 GB boot serial no: Z2010V20816UG039046 serial no: Z2010V20816UG039046 baseband version: FM_BASE_15B_Release_W16.14.6_P2|sc9830_modem|04-28-2016 11:52:05 ril version: android reference-ril 1.0 sim state: ABSENT,NOT_READY sim operator: 3() network type: HSPA,Unknown signal strength: 0 dBm (99 asu) (no service) signal strength: 0 dBm (99 asu) (no service) android_id: 8982e057ff0e8d45 bt addr: 00:27:15:08:78:df wifi mac: country: ID language: in battery level: 77% superuser: no Android shell does not have root access read info and reset via svc mode but problem not solved Code: Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_W15.7.2_Debug Project : sharkl_cp1 HWInfo : sc9830_modem Phone Security Info : IMEI [1] : 061300924A35766 IMEI [2] : 061400922000000 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.935 V Done Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Init Ok , reset settings ... Format Ok! Done Elapsed: 00:00:24 Reconnect Power/Cable! Code: Start at : [12/12/2016 / 10:36:08 PM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [12/12/2016 / 10:37:04 PM] SLDR Load Ok BB CPU : SC9830 SC9830 TBL V1.0 eMMC loader A5 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [12/12/2016 / 10:37:39 PM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable try with all possibe boot keys and sldr mode fail battery 80% and cable is good any suggestion?? |
12-12-2016, 17:44 | #8 (permalink) |
Member: 1128422 Status: Offline Thanks Meter: 67 | i have did my best..., but still no luck Code: Start at : [12/13/2016 / 12:34:00 AM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [12/13/2016 / 12:34:52 AM] Start at : [12/13/2016 / 12:35:09 AM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [12/13/2016 / 12:35:53 AM] SLDR Load Ok BB CPU : SC9830 SC9830 TBL V1.0 eMMC loader A5 For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [12/13/2016 / 12:36:23 AM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [12/13/2016 / 12:37:06 AM] Start at : [12/13/2016 / 12:37:17 AM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
12-12-2016, 19:22 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SC9830_R3_EMMC.sldr ? RGhost ? ????????????? Download, select SC77xx mode, select that sldr. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
12-12-2016, 20:02 | #10 (permalink) | |
Member: 1128422 Status: Offline Thanks Meter: 67 | Quote:
Code: SLDR Load Ok BB CPU : SC9830 SC9830 rev3 eMMC For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [12/13/2016 / 2:58:33 AM] Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC R4 (c) Infinity-Box Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : chinapalms_4m_oversea Model Brand : ADVAN Model Device: i5C AndrVersion : 5.1 BaseBand CPU: CHINAPALMS_4M_OVERSEA CompileDate : 8/30/2016 12:05:04 PM Project Ver : i5C_LF5029_V2_20160830 Model Ext : i5C ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:28 Reconnect Power/Cable! Finish at : [12/13/2016 / 2:59:01 AM] thx | |
12-13-2016, 12:42 | #11 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | As I Know It Work Perfectly Problem With User Either He Not Press Right Boot Key @ Right Time Or Left Before Boot Completely..... I Test This Model Few Days Back Working Fine.....If U Face Problem Better Load Factory File N Try To Do Operation It Will Pick Loader From .Pac |
12-13-2016, 12:56 | #12 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
12-14-2016, 06:54 | #13 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
Worked For Me Without Issue ...Same Brand Same Model..... | |
12-16-2016, 16:28 | #14 (permalink) | |
hiii..., for me it is different problem. and different brand/ model just see the log carefully my problem solved with this sldr http://forum.gsmhosting.com/vbb/12217320-post9.html Code: Chinese Miracle II [SPD module] v 1.24 SLDR Load Ok BB CPU : SC9830 SC9830 rev3 eMMC For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [12/13/2016 / 8:05:11 AM] Operation : Read FullFlash [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC R4 (c) Infinity-Box Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC R4 (c) Infinity-Box Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC9830 eMMC R4 (c) Infinity-Box Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : chinapalms_4m_oversea Model Brand : ADVAN Model Device: i5C AndrVersion : 5.1 BaseBand CPU: CHINAPALMS_4M_OVERSEA Project Ver : i5C_LF5029_V2_20160830 Model Ext : i5C [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : nvitem_l.bin [Read Ok] : sharkl_cp1.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : l__WPH_arm7.bin [Read Ok] : PM_arm7_sys.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : wcn_fdl.bin [Read Ok] : AA_MARLIN.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : oem.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1659 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\CHINAPALMS_4M_OVERSEA_i5C_5.1_i5C_LF5029_V2_20160830_i5C\ Done! Elapsed: 00:14:24 Reconnect Power/Cable! Finish at : [12/13/2016 / 8:19:35 AM] ========================= Start ========================= 12/13/2016 / 9:41:14 AM ========================================================= Card found: S/N : EE9E9262 , v0134 Chinese Miracle II [SPD module] v 1.24 Loading : i5C_LF5029_SC9830_Z201D1_flash8 1_5.1_20160715.pac CRVersion : BP_R1.0.0 PacCPUinfo : PAC_SharkL5ModeMarlinAndroid5.1 PacVersion : i5C_LF5029_V2_20160715.pac FastCheck : 0x005884BB14 Loading files ... File : fdl1.bin File : fdl2.bin File : Z201_nvitem_jhq_lf5029_201607015.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC9600_sharkl_5modcsfb_volte_FM_BASE_15B_W16.14.6_P2.bin File : LTE_DSP_FM_BASE_15B_W16.14.6_P2.bin File : SHARKL_DM_DSP_FM_BASE_15B_W16.14.6_P2.bin File : SC9600_sharkl_wphy_5mod_volte_FM_BASE_15B_W16.14.6_P2.bin File : PM_sharkl_arm7_FM_BASE_15B_W16.14.6_P2.bin File : fdl1_Marlin_15A_W16.09.2.bin File : EXEC_KERNEL_IMAGE0_Marlin_15A_W16.09.2.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo_normal.bmp File : logo_fastboot.bmp File : cache.img File : u-boot.bin File : persist.img File : oem.img File : SharkL5ModeMarlinAndroid5.1GMS.xml Load Ok! Start at : [12/13/2016 / 9:44:20 AM] Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000155AF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:48 | |
12-16-2016, 18:23 | #15 (permalink) | |
The Following User Says Thank You to hitech care For This Useful Post: |
