LYF ls 5015 unable to read and showing eroor Card found : 9E982DF6 , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 09D1D65D ID_BLOCK_I : 009600E1 ID_BLOCK_L : 6A9AF00EA935222D1A4F818E4910A0A8 ID_BLOCK_L : 88FB45E4E978E26366513AF3F13C2A11 Use CM2 Internal Loader FH_LOAD_CODE : 14 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 09D1D65D ID_BLOCK_I : 009600E1 ID_BLOCK_L : 6A9AF00EA935222D1A4F818E4910A0A8 ID_BLOCK_L : 88FB45E4E978E26366513AF3F13C2A11 Use CM2 Internal Loader FH_LOAD_CODE : 11 Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 09D1D65D ID_BLOCK_I : 009600E1 ID_BLOCK_L : 6A9AF00EA935222D1A4F818E4910A0A8 ID_BLOCK_L : 88FB45E4E978E26366513AF3F13C2A11 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Error : Failed to read initial info! Erased/Damaged device??? Check cable, connection and drivers! Reconnect Power/Cable! Sent from my iPhone using Tapatalk |
faild to read initial info Erased/damged device check cable connection and drivers answer in ur logs |
that phone condition alive or dead ??? |
alive Sent from my iPhone using Tapatalk |
Connection is losing in middle charge battery and change USB cable use short good USB cable and also use mother board port Sent from my S_plus using Tapatalk |
