05-29-2019, 04:35 | #1 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Infinity Chinese Miracle-2 SPD/UniSoc v2.00 r1 - Initial Release! - Supported platforms: SpreadTrum: SC5735 SC7715 SC7731C, SC7731G SC9820 SC9832A SC9850 SC9853i UniSoC: SC9820E SC7731E SC9832E SC9850K SC9850KH SC9863 - Support Generic (Non-Secure), SecureV1, SecureV2 devices Android 4/5/6/7/8 versions - Supported operations in initial release: Identify ( include complete device info ) Reset Settings / Format FS Reset FRP Firmware flashing ( Safe Flash, Repartition, HW verify, Flash customizing ) - Database: Basic wide-range bootloaders for common devices types Also lot of other pre-defined models already included in database - Extra: Feature: Completely safe flash engine ( allow flash SimLock / Signed / and other devices, recover critical data from semi-damaged NV ) Feature: Automatic ModelDB update at new model detection ( loader select, pac load etc. ) Feature: Customized boot option and sources: Manual PAC, Manual FDL pair with automatic details detection, Pre-defined DB, Self-Learning DB Feature: Complete Firmware Info detection at FW load with extended info Download Link |
The Following 18 Users Say Thank You to kamal_singla For This Useful Post: |
05-29-2019, 04:52 | #6 (permalink) |
No Life Poster Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 225 | From the previous version 1.27 Supports something Or just a new chipset |
The Following User Says Thank You to afghanistanmob For This Useful Post: |
05-29-2019, 05:16 | #9 (permalink) |
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Intex Aqua Lions 4G Identify, Format FS, Flashing Code: Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : INTEX_AQUA_LIONS_4G_V08_Indian_SER Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-01-05 Build Time : 1487606400 Product Model : INTEX AQUA LIONS 4G Product Brand : INTEX Product Name : INTEX_AQUA_LIONS_4G Product Device : INTEX_AQUA_LIONS_4G Product Board : INTEX Product Manfct : INTEX Board Platform : sc8830 Product Info : INTEX AQUA LIONS 4G UserData : STATE : DAMAGED Done! Elapsed: 00:00:34 Code: Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:34 Code: Operation : Flash Firmware [ v2.00r1 ] Setting : Update NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x26 PMTMng : Update PMT Ok! CODE : prodnv.img ERASE : UBOOT UBOOT : u-boot-spl-16k.bin CODE : ltemodem.bin CODE : ltedsp.bin CODE : ltegdsp.bin CODE : ltewarm.bin CODE : pmsys.bin CODE : wcnfdl.bin CODE : wcnmodem.bin CODE : boot.img CODE : recovery.img FSIMG : system.img FSIMG : userdata.img CODE : logo.bmp CODE : logo.bmp FSIMG : cache.img ERASE : L_RUNTIMENV1 ERASE : MISC FSIMG : persist.img CODE : sysinfo.img UBOOT : u-boot.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:04:14 |
The Following 3 Users Say Thank You to kamal_singla For This Useful Post: |
05-29-2019, 05:37 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,931 | Here is info - https://www.infinity-box.com/support/?r=100077 |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
05-29-2019, 05:43 | #12 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 931121 Status: Offline Thanks Meter: 100 | symphony i95 format done by infinity box Card found : 64C1CE3F , v0137 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1 Operation : Identify [ v2.00r1 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Done! Elapsed: 00:00:43 Operation : Format FS / Reset Settings [ v2.00r1 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:45 |
The Following 4 Users Say Thank You to moniuzzaman For This Useful Post: |
05-29-2019, 06:59 | #15 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ Require Your Smart Card Ver Is v0137 ..... |
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post: |
