04-01-2016, 07:26 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Peshwar, Pakistan
Member: 2192793 Status: Offline Thanks Meter: 188 | Need this file SMDK4210__samsung__GT-S7582__bird75_d_cu_ics__4.2.2__ALPS.ICS.MP.V2.16 if someone plz have this file, share it thanks in advance. . . "SMDK4210__samsung__GT-S7582__bird75_d_cu_ics__4.2.2__ALPS.ICS.MP.V2.16" Operation : Read Flash [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594812A18C763E9FE9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 927D16C677E9E8D1D2726E36171D1AFD INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7582 Device : bird75_d_cu_ics AndroidVer: 4.2.2 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 [Read Ok] : preloader_ztesz75_cu_ics.bin [Read Ok] : DSP_BL [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6575 / V1.0.0 / ztesz75_cu_ics / EMMC Android Info saved FW Size : 440 MiB Scatter saved to : C:\Documents and Settings\Admin\Desktop\Temp Flash\SMDK4210__samsung__GT-S7582__bird75_d_cu_ics__4.2.2__ALPS.ICS.MP.V2.16\ All done! Done! Elapsed: 00:03:44 Reconnect Power/Cable! |
