03-08-2011, 09:03 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: India
Member: 583492 Status: Offline Thanks Meter: 125 | M9 successfully repair No licensed to produce" solution by Infinity-Box COM145 [VCP1] selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ ANX_M9_T3ZSP_V04__fullflash_20110308-131838.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1D03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\ChineseMiracle\backup_security\id.C 2F398C8.[GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ ANX_M9_T3ZSP_V04.BIN_ABD079C0].rpl ==================== New firmware found (v.3.27, database date: 03.03.2011): GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ ANX_M9_T3ZSP_V04.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: C2F398C8 rom info ver: 07 sw version: GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ ANX_M9_T3ZSP_V04.BIN project-id: A19_ANX_M9_T3ZSP_V04, C079D0AB code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ ANX_M9_T3ZSP_V04__ffs... file saved: C:\InfinityBox\ChineseMiracle\GOLDDRAGON25_09A_GEM INI_PCB01_GPRS_MT6225_S00.A19_ANX_M9_T3ZSP_V04__ff s_20110308-132919.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... No licensed to produce fix... No licensed to produce done Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... rpl file not found: c:\InfinityBox\ChineseMiracle\id.C2F398C8.[GOLDDRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ ANX_M9_T3ZSP_V04.BIN_ABD079C0].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\id.C2F398C8._GOLDDRA GON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ANX_M9_ T3ZSP_V04.BIN_ABD079C0_.rpl startup code area #1 backup loaded startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: c:\InfinityBox\ChineseMiracle\backup_security\GOLD DRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ANX_ M9_T3ZSP_V04__system_log_C2F398C8_ABD079C0_2011030 8-132931.B0X.bin Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\ChineseMiracle\backup_security\GOLD DRAGON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.A19_ANX_ M9_T3ZSP_V04__system_log_C2F398C8_ABD079C0_2011030 8-133033.B0X.bin Finished, time used: 3 min 36 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to afhaan For This Useful Post: |
03-08-2011, 09:24 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, If phone is working fine then read full flash and send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
