MeanIT K7 Kids RK3126C FRP OK BUT STILL LOCKED Where is problem? Log is here: ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0100 Machine : RK312X Device : RK3126C ExtInfo : 7.0.0 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C646456A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020D000000 ( 8,20 GiB ) Flash Info : 6291456/12288/32/60/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:03 |
Hi, Do you see any changes with the message at phone screen after the operation ? |
No it is the same and tablet is still conected to wifi after frp and reset |
What is the exe version do you use ? (I don't see version number at log) |
Infinity-Box RockChip Service Tool [RKT] v2.02 |
When I try older version I get this: Operation : Reset Settings [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Device connection test not passed! Breaking! Probably you boot device in wrong mode! Device not found! Remove battery, cable. Check cable and connection. Repeat operation! |
Operation : Reset Settings [ v2.02 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : 0x0100 Machine : RK312X Device : RK3126C ExtInfo : 7.0.0 SoC CPU : 312A Flash CSx : 0x00 Flash Type : 2C646456A5 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000020D000000 ( 8,20 GiB ) Flash Info : 6291456/12288/32/60/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:03 |
Here is readed flash file from tablet RK3126C__meanIT__meanIT_K7__7.1.2__IntelkomK7V0.2_ _NHG47K__rk3126c |
With older drivers it is working with version 2.01 but same, frp done ok but still locked |
It looks like need to wait the next software release, programmers informed about your device, check is in progress |
I already tried hard reset before unlock and after unlock and still locked |
