09-28-2017, 22:24 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | It's normal, non-secured boot phone. Try to boot phone while holding Volume DOWN button + insert usb cable. post boot logs. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
09-28-2017, 22:26 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | Already tested with volume down and up and together but nothing work its secured boot bro need da file Envoyé de mon iPhone en utilisant Tapatalk |
09-29-2017, 00:02 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Asus Zenfone Pegasus 3 / X008 / ZC520TL Okay, boot files - HERE Scatter file attached or use from firmware archive ... Stock scatter ROM files - HERE If, for some reason need original flasher ... download - HERE try and post results ... b.r. Alex
The Following 4 Users Say Thank You to Brka For This Useful Post: |
09-29-2017, 01:25 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Once again... If you have exactly : asus x008, ZC520TL, It's mt6737t cpu. Try booting with provided loaders, do read info in cm2, And finally post operation log here. B.r. Alex
09-29-2017, 05:17 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Do you have Infinity box at all ? b.r. Alex
09-29-2017, 16:25 | #12 (permalink) |
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 |
09-29-2017, 16:40 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | I posted for you all you need. Follow guide, replace da_agent, try to boot phone. http://forum.gsmhosting.com/vbb/f296...tarts-2269144/ Or, install original flasher, link in my previous posts, Use loaders from it. B.r. Alex
