03-03-2016, 15:15 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Algeria is a North African Age: 35
Member: 1629321 Status: Offline Thanks Meter: 823 | Memory emmc problem for your Condor c2 emmc problem for your Condor c2accept Flash accept format But after the restart back as before as if you did not work with anything Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034472853D02FAA515D Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034472853D02FAA515D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 980CF983F2BAED549344CE8A30763D68 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : SPA CONDOR ELECTRONICS ProdName : tianyu72_wet_jb3 ProdModel : PKT-301 Device : tianyu72_wet_jb3 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 SECURITY : IMEI_SW [1] : vvvvvvvvvvvvvvvvv IMEI_SW [2] : vvvvvvvvvv BTMAC Addr : 121421044047 WiFi MAC : 802275242AB6 EXTRA : LCD [0] : ty_hx8357c_hvga_mcu_quality LCD Res : 480x320 TOUCH [0] : msg2133 CAM [0] : ov2655_yuv CAM [1] : ov2659_yuv MODEM : tianyu72_wet_jb3_hspa LOCALE : fr_FR en_US it_IT es_ES de_DE nl_NL cs_CZ pl_PL ja_JP zh_TW zh_CN ru_RU ko_KR nb_NO es_US da_DK el_GR tr_TR pt_PT pt_BR rm_CH sv_SE bg_BG ca_ES en_GB fi_FI hi_IN hr_HR hu_HU in_ID iw_IL lt_LT lv_LV ro_RO sk_SK sl_SI sr_RS uk_UA vi_VN tl_PH ar_EG fa_IR th_TH sw_TZ ms_MY af_ZA zu_ZA am_ET hi_IN hdpi mdpi Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
03-03-2016, 16:04 | #3 (permalink) |
Member: 1629321 Status: Offline Thanks Meter: 823 | Operation : HW Test [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034472853D02FAA515D Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034472853D02FAA515D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 980CF983F2BAED549344CE8A30763D68 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3881 mV [Processing] FlashMemory Read-Write test [eMMC] : [SANDISK] , G40ME , 0xEC000000 , 3776 MiB [eMMC] : CID : 45010053454D3034472853D02FAA515D [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! |
