11-24-2015, 12:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | Micromax A76 fully Dead Recover Just Format only with Cm2 Code: Card found : Chinese Miracle II [MTK module] v 1.37 Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D024A8ECE3DB013 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D024A8ECE3DB013 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E355530304D024A8ECE3DB013 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D024A8ECE3DB013 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Momin_Telecom Last edited by Momin_Telecom; 11-24-2015 at 12:19. |
The Following 3 Users Say Thank You to Momin_Telecom For This Useful Post: |
11-24-2015, 12:29 | #2 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: mystery city
Member: 1199392 Status: Offline Thanks Meter: 95 | Quote:
bro pls upload scattr file | |
11-24-2015, 14:12 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Here is FF read with CM2- http://forum.gsmhosting.com/vbb/f296...l#post11431592 Will try to upload directly on Infinity server. But will have to wait as my upload speed is slow. Br. |
11-24-2015, 16:50 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, MT6572__ Micromax A76___4.2.2__ALPS.JB3.MP.V1 File uploaded to server2/ flashfiles / 0-CommunityUploads / It's ready for download for all users. Br. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
11-25-2015, 05:39 | #6 (permalink) | |
micromax a76 micromax a74 micromax a111 pls upload any time available sctter file in 3 model original file not available in sctter file if supported update only recovery mode like this: Please use 2GB or 4GB formatted memory card to flash the device. Steps: copy the software zipped file in to memory card>> now press volume up and power key together. | |
11-25-2015, 07:17 | #7 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
MMX A76 file is already uploaded to Infinity server-2 yesterday- http://forum.gsmhosting.com/vbb/f296.../#post11432021 Download it from server-2. MMX A74 is already available in scat format over forum, just search it. If you still need it I will upload it to Infinity server. MMX A111 has Qualcomm MSM8225Q Snapdragon S4 Play chipset, it's not MTK so not possible to make scat backup. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
