04-02-2015, 10:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | micromax A77 working NV file need please help Code: Chinese Miracle II [MTK module] v 1.15 Operation : Check / Read Info [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048600A3EFE4B041 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3EFE4B041 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A77 ProdModel : Micromax A77 Device : A77 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ZA1005C_060A_V8_0_3 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Repair Security [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 91133825xxxxs failed , record not exist or NVRAM damaged! Update IMEI[2] to : 911338251xxxxx failed , record not exist or NVRAM damaged! Update IMEI[3] to : 9113382xxxx failed , record not exist or NVRAM damaged! Update IMEI[4] to : 9113382xxx failed , record not exist or NVRAM damaged! Done! Elapsed: 00:07:50 Reconnect Power/Cable! Last edited by kariakala; 04-02-2015 at 10:46. |
04-02-2015, 10:57 | #2 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: India Age: 25
Member: 2335317 Status: Offline Sonork: 100.1663571 Thanks Meter: 148 | Quote:
6572 nv tested - Download - 4shared - Zs Malik B.R. ZS MALIK | |
The Following User Says Thank You to zsmalik786 For This Useful Post: |
04-02-2015, 12:04 | #5 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Unknown baseband repair still not supported, but will be supported in coming updates. For now try to flash phone with original factory firmware or with dump read with other working phone. Sometimes it also requires to format and then flash factory firmware to repair unknown baseband. Br. | |
04-02-2015, 14:04 | #6 (permalink) | |
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
I do repaired unknown baseband and imei fixed too with help of NV posted above in this thread | |
