Old 05-13-2011, 17:37   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
cant write imei inside firmwer
plz help set is working condition but cant repier imei
COM4 [Serial2] selected
module v3.30
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 358295002600207
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1103:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: JWT_Z101B_001_PCB01_GPRS_MT6225_S00.LB0MM06_8_32_1 _1T08M0106_M570.BIN
project-id: LB0MM06.8.32.1.1T08M0106_M570, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
error: ffs/eeprom detection failed element #2
error: can not detect default imei value
Patch required data Fail
Finished, time used: 1 min 34 sec
Remove/Install battery now !
Old 05-13-2011, 18:06   #2 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
try to change different mathode in software and use low speed
Old 05-13-2011, 18:15   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
bro i use this speed
Old 05-13-2011, 18:22   #4 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
r you connect phone direct rx,tx tp to box or via pinfinder?
Old 05-13-2011, 18:23   #5 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
via pinfinder interface
Old 05-14-2011, 21:03   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
use IMEI change method 1 or 2.
do not use this "inside firmware" option
if will not work- post logs
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.15666 seconds with 9 queries
