Micromax Q5 Dead After Flash Micromax Q5 Dead After Flash Before Flashing Set hang On Opening Camera But After Flashing handset Dead Log Here COM2 [VCP0] selected module v3.62 Device: Micromax-Q5 Checking data, wait... Action: write flash NAND write: Firmware Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_08_2010-01-09_En_ver2.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_08.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: E521_MP_F1_IN_MMX_05.08 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_08.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN project-id: E521_MP_F1_IN_MMX_05.08, 0556E59E code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.62, database date: 13.01.2011): TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_08.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN_9EE55605].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\id.00006235._TINNO35_09A _PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_MMX_05_08.BI N_9EE55605_.rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235.[TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN_9EE55605].rpl rpl file not found: C:\Program Files\InfinityBox\MModule\backup_security\id.00006 235._TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1 _IN_MMX_05_08.BIN_9EE55605_.rpl ==================== warning: unknown firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN_9EE55605 Unknown firmware found (v.3.62, database date: 13.01.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_IN_M MX_05_08.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . . . . write core... Format (HW_STORAGE_NAND)... Disconnect... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_08__system_log_20110405-163922.B4X.bin Finished, time used: 43 min 28 sec Remove/Install battery now ! Pls Help |
micromax mostly dead after flash |
try this fly for flashing hope ur problem solve download infinity site Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E580_MP_F1_I N_MMX_15_13_2010-06-25_En.B4M.bin try and post result |
Infinity team help....... Quote:
Brother when i flash with this file my phone switch on but hang on first screen & wrong key working like when i press clear button working 0 button & when i press call button working 7 button please help |
pls help me brother RAGA RQ 101 ki flash file dedo mujhe bahut jaroorat hai |
u flahed the phone with which box br... |
My Problem Solve successfully By Mr.Omegasekar He give me process I Have done Step By Step... 1.1st Whole Erase Flash 2.Flash With New File with Support Area.. & Then My Set Working Normally Thanks Mr.Omegasekar |
haiiiiiiiiiiiiiiiiii Quote:
i really thank u |
Log Here COM2 [VCP0] selected module v3.62 Device: Micromax-Q5 Checking data, wait... Action: write flash NAND write: Firmware Micromax-Q5_TINNO35_09A_PCB01_GPRS_MT6235B_S01.E521_MP_F1_I N_MMX_05_09_2010-03-01_En.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_09.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... bootloader version: TINNO35_09A_BOOTLOADER_V005_MT6235B_E521_MP_F1_IN_ MMX_05_09.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . write core... Disconnect... done Finished, time used: 7 min 48 sec Remove/Install battery now ! |
