03-16-2018, 10:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Micromax x263 flash file wanted module v4.48 Device: _Autodetect MT6205-6239 NOR Checking data, wait... Operation: Read Information mode-2 META interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6252 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: 1511A_0101_V0914 H/W board version: GIONEE52_6432_10A_HW Melody version Melody V0.0 Version: 1511A_0101_V0914 ==================== New firmware found (v4.48, database date: 27.03.2014): 1511A_0101_V0914 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure imei... done 136 byte(s) read imei #1: imei #2: Shutdown... done Finished, time used: 37 sec Remove/Install battery now ! i want micromax x263 flash file.. handset not detect readfirmware time |
03-16-2018, 11:03 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, File uploaded to server- http://forum.gsmhosting.com/vbb/13023572-post980.html Will be available for download soon. Br. Infinity Box Team. |
03-16-2018, 11:39 | #4 (permalink) |
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | COM26 [VCP0] selected module v4.48 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Micromax-X263_WBG1007A_0202_PCB01_GPRS_MT6253_S00.1007A_020 2_V0761.BIN_FLNK5N2833ATB_AQ12000.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Press and HOLD Power button now ! |
03-16-2018, 13:00 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Press boot key and connect phone (use CM2MTK) or find pinout with Infinity- Box pinout finder and proceed (MModule). Br. Infinity Box Team. |
03-16-2018, 14:18 | #6 (permalink) |
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | sir...i trayed in cm2mtk module...error come Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 00C3 BB_CPU_HW : 0001 BB_CPU_SW : D267 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BROM Protocol Version : FF Setting... Setting done , result code 0x430E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! pin out correct..read info ok in mm module..but not detect handset in flashing time..need help |
03-17-2018, 08:10 | #9 (permalink) |
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | hello..error come COM26 [VCP0] selected module v4.48 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Action: write flash write: Firmware Micromax-X263_WBG1007A_0202_PCB01_GPRS_MT6253_S00.1007A_020 2_V0761.BIN_FLNK5N2833ATB_AQ12000.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6250:CA02:0100 status: FF bbchip bl ver: FE NOR chip is not detected NAND chip is not detected Repeat operation, Press and HOLD Power button more long time ! internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 0C0B:S_DA_UNSUPPORTED_BBCHIP error: last error: 0C0B:S_DA_UNSUPPORTED_BBCHIP Disconnect... done Finished, time used: 23 sec Remove/Install battery now ! |
03-17-2018, 08:43 | #10 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Use MT6252 firmware and check result. In your 1st post you can see cpu details- MT6252 and you are using MT6253 firmware. Change firmware and try again. Br. Infinity Box Team. |
03-17-2018, 13:24 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Read carefully, your 1st post HERE shows phone has MT6252 and your are asking for 6253 firmware!!?? MT6252 based firmware for X263 already uploaded on support- http://forum.gsmhosting.com/vbb/13023572-post980.html, download and flash it. Br. Infinity Box Team. |
