03-10-2011, 22:41 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Badui My home
Member: 508048 Status: Offline Thanks Meter: 123 | Hardware version: MT6268B whether it could be (need answers) Code: Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6268B, E0 Hardware version: CKT68_09B_HW Software version: VIOLIN-S02_METROTECH Software date: 2000.00.00 Barcode: 058GACU045511H imei-1: 353256044619030 imei-2: 353256044721034 imei-3: 353256044619030 Finished, time used: 10 sec Remove/Install battery now ! Code: COM3 selected module v3.27 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 10 sec Remove/Install battery now ! and what should I do .. phone can not play (multimedia menu) music and hank thx... |
03-11-2011, 00:05 | #3 (permalink) |
Member: 508048 Status: Offline Thanks Meter: 123 | Code: COM3 selected module v3.27 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6268:8B01:8B01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0048]: 0098:00C100900055 [TOSHIBA] TC58NWG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done interesting cpu type found: 6268:8B01:8B01 ram test... testing... warning: ram test failed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: VIOLIN-S02_METROTECH_L2IN_217_101201_CAM200_MCP1024_BT_FM detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: METROTECH_S02_PCB01_UMTS_MT6268_S01.VIOLIN-S02_METROTECH_L2IN_217_101201_CAM200_MCP1024_BT_FM.BIN project-id: VIOLIN-S02_METROTECH_L2IN_217_101201_CAM200_MCP1024_BT_FM, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.27, database date: 19.01.2011): METROTECH_S02_PCB01_UMTS_MT6268_S01.VIOLIN-S02_METROTECH_L2IN_217_101201_CAM200_MCP1024_BT_FM.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... |
03-11-2011, 00:39 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I think phone will be alive. I suggest you to make full flash backup and send backup file (or link) to [email protected] to check |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
