09-06-2017, 11:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Micromaxx A064 By Mistake Flash by A065 Now Dead then i again flash with a064 and init preloader also erase whole flash again flash with a064 STILL PRELOADER STATUS NOT ACTIVE HERE IS LOGS; Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 296 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E987A429169 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E987A429169 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0xFADB6BFD06348EB1185D298B4E7CF51A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A064 ProdModel : Micromax A064 Device : A064 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : MMX_A064_SW_V8.0.3_HW_V1.0_20140827 MODEM : BaseBand : MT6571_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_2g_n EXTRA : LCD [0] : nt35310_dbi_6571_hvga_aw268 LCD [1] : ili9488_dbi_6571_hvga_aw268 LCD Res : 480x320 TOUCH [0] : msg2133_aw268 TOUCH [1] : ft6206_aw268 CAM [0] : gc0328_yuv_zaw268 CAM [1] : gc0329_yuv_zaw268 MODEM : zaw268_mmx_modem_gprs_900_1800 LOCALE : en_US hi_IN mdpi Done! Elapsed: 00:00:20 Reconnect Power/Cable! WHERE I DO MISTAKE Br., Puneet5154 |
09-06-2017, 11:17 | #3 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | AFTER ERASE LOGS: Code: Wait for phone... Phone found! [ 296 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E987A429169 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E987A429169 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0xFADB6BFD06348EB1185D298B4E7CF51A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
09-06-2017, 12:57 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Reflash phone with original FW now. Write NVM. Make identify after. | |
09-06-2017, 14:23 | #6 (permalink) | |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
ERASE WHOLE FLASH WITH PREOLOADER REFLASH FLASH WITH ORIGINAL FIRMWARE WRITE NVM(READ FROM WORKING PHONE) STILL SAME Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 296 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E987A429169 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E987A429169 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0xFADB6BFD06348EB1185D298B4E7CF51A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A064 ProdModel : Micromax A064 Device : A064 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : MMX_A064_SW_V8.0.3_HW_V1.0_20140827 SECURITY : IMEI_SW [1] : 911370300444713 IMEI_SW [2] : 911370300596264 BTMAC Addr : EEBD256571C2 WiFi MAC : 4491DB1402D7 MODEM : BaseBand : MT6571_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_2g_n EXTRA : LCD [0] : nt35310_dbi_6571_hvga_aw268 LCD [1] : ili9488_dbi_6571_hvga_aw268 LCD Res : 480x320 TOUCH [0] : msg2133_aw268 TOUCH [1] : ft6206_aw268 CAM [0] : gc0328_yuv_zaw268 CAM [1] : gc0329_yuv_zaw268 MODEM : zaw268_mmx_modem_gprs_900_1800 LOCALE : en_US hi_IN mdpi | |
09-09-2017, 15:05 | #9 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | SAME ISSUE Code: Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E987A429169 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E987A429169 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0xFADB6BFD06348EB1185D298B4E7CF51A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! |
