11-23-2015, 06:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx aq5001 read ff error Code: Operation : Read Flash [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523758314D42098869CCCE521F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM1X7 [eMMC] : FLASH_CID : 150100523758314D42098869CCCE521F [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : AQ5001 ProdModel : Micromax AQ5001 Device : AQ5001 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : MMX_AQ5001_SW_V1.0.3_HW_V1.0_100215 [Read Ok] : preloader_zaw1055.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Error] : Bad EXT data Looks like unusable file , break! Read Ok , collect info Brand : Micromax ProdName : AQ5001 ProdModel : Micromax AQ5001 Device : AQ5001 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : MMX_AQ5001_SW_V1.0.3_HW_V1.0_100215 File conversion error, file already exists! Saved as default! Done! Elapsed: 00:10:56 Reconnect Power/Cable! |
11-23-2015, 11:23 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It FactoryEncrypted phone. If data inside not matter : 1. Repair EXTData 2. Power On phone, connect USB cable and press Read FW. Maybe, will be need press read FW 2 times, if phone will not off during first try. Wait. |
