Old 01-16-2011, 14:10   #1 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Club C200 [Read firmware] [Pinouts]
Format log:
COM42 [VCP4] selected
module  v3.25
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:72E5:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 7F227E220A2201:2BEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
flash: 7F227E22002201:2BEA0000000000
error: detected/calculated [00400000/00000000] chip size mismatch, chip detection failed
number of flash chip/regions detected: 08/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.25, database date: 24.10.2010):
HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.F021_2A_CLUB_V49.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.F021_2A_CLUB_V49.BIN
project-id: F021_2A_CLUB_V49, 00000000
code offset: 00000000
ffs offset/size [01]: 00380000/00080000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00380000
standard ffs/eeprom offset confirmed: 00380000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00380000-003FFFFF
firmware area: 00000000-0037FFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.F021_2A_CLUB_V49__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.F021_2A_CLUB_V49__ffs_20110116-170307.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 59 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Readfirmware log:
module  v3.25
Action: read firmware
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
checking area [00000000]: 00080000-003FFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00380000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
ffs/eeprom chip: 00
reading: HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.F021_2A_CLUB_V49__firmware_part_1_of_1...
file saved: C:\Documents and Settings\Shakeel Software\Desktop\HEXING23D_GEMINI_ULC_07B_PCB01_GSM_MT6223_S00.F021_2A_CLUB_V49__firmware_part_1_of_1_20110116-170717.B0M.bin
Finished, time used: 3 min 36 sec
Pinouts:
Download link flash file:
The Following 2 Users Say Thank You to Shakeel_pattoki For This Useful Post:
Old 01-16-2011, 21:26   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you, downloaded!
Old 05-30-2011, 10:06   #3 (permalink)
Member: 1586115
Thanks Meter: 14
Old 07-04-2011, 08:23   #4 (permalink)
Member: 352564
Sonork: 100.1592785
Thanks Meter: 23
bad file please chk again
Old 07-04-2011, 08:57   #5 (permalink)
Member: 352564
Sonork: 100.1592785
Thanks Meter: 23
its tested on club c200 and work fine ......................
Club C200
The Following 2 Users Say Thank You to shahzad_lal For This Useful Post:
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.20479 seconds with 9 queries
