01-17-2016, 12:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | MMX A93 dead done by only init preloader Code: User selected Preloader file : preloader_fars72_wet_v115_jb3.bin Operation : Init Preloader [ v1.40 ] Supported HW by Preloader : FlashID [0] CID : 1501004B355530304D , Name : K5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 364 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034472843946C91B075 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034472843946C91B075 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 1501004B355530304D , Name : K5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 1799 PartTable Init Ok , Count : 14 All Done Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034472843946C91B075 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034472843946C91B075 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : Micromax A93 ProdModel : Micromax A93 Device : A93 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.15 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V10_1_wg_n EXTRA : LCD [0] : fussen_t850_otm9605a_dsi_gx LCD Res : 960x540 TOUCH [0] : ft5436i CAM [0] : ov5645_mipi_yuv CAM [1] : gc0328_yuv CAM [2] : gc0329_yuv MODEM : fars72_wet_v115_jb3_wg128hspa LOCALE : en_US hi_IN hdpi Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
