11-20-2017, 13:45 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | Mobile 10.or.G frp Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 07F484CA ID_BLOCK_I : 000460E1 ID_BLOCK_E : 07F484CA ID_BLOCK_L : 96DF42F8F4C2AEC586705CDD31096E40 ID_BLOCK_L : 95F4C09448196C57942C6A2791B9090C Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! can u please make any loaders or can I read something and send you to get support. |
11-20-2017, 13:48 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Plz use latest QLM version tht is 1.15 u can check here http://forum.gsmhosting.com/vbb/f296...tures-2246106/ |
11-20-2017, 14:44 | #3 (permalink) |
Member: 433257 Status: Offline Thanks Meter: 43 | sorry for the above post here is the log of v1.15 Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 07F484CA ID_BLOCK_I : 000460E1 ID_BLOCK_E : 15900001 ID_BLOCK_L : 96DF42F8F4C2AEC586705CDD31096E40 ID_BLOCK_L : 95F4C09448196C57942C6A2791B9090C Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-21-2017, 08:31 | #5 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
You need to wait for update or if you have it's firmware select it in flash tab and repeat process. To make this phone supported follow software hint- Code: Send log and report.log to support! Include device info also! Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
01-18-2018, 05:41 | #7 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | not supporting in Tenor D model also Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 3B745C31 ID_BLOCK_E : 00460066 ID_BLOCK_L : 5E03704610E4BAD04D5EF8EEE88423E6 ID_BLOCK_L : 544710E07ED121E6E9A8249D3877F947 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
01-18-2018, 15:11 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,537 | Quote:
04-01-2018, 06:36 | #11 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Quote:
Good Luck | |
The Following User Says Thank You to gracy_elec For This Useful Post: |
