11-20-2008, 12:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>>> Vodafone 226FM Restart Problem Solved <<<< Thanks to Infinity Team ...... module v1.55 Device: Vodafone-226FM Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sta_20081120-153838.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-sec_20081120-153841.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20081120-153843.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 30 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to zeel_zeel For This Useful Post: |
11-20-2008, 15:07 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
12-01-2008, 15:22 | #3 (permalink) |
Freak Poster Join Date: Apr 2008 Location: mahesana gujrat.india
Member: 751845 Status: Offline Sonork: no life poster Thanks Meter: 64 | Thanks for the info. Really it good wook >>>> Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work>>>jayan |
12-03-2008, 14:22 | #4 (permalink) |
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Another same case solved by Infinity >>>>> COM5 [VCP0] selected module v1.57 Device: Vodafone-226FM Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EDI_IF EDI_IF_040108_1352 040108_1352 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-static_20081203-125846.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-security_20081203-125847.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-226FM_eeprom-complete_20081203-125848.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 31 sec Remove/Install battery now ! |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
12-03-2008, 17:52 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
01-14-2009, 10:18 | #6 (permalink) |
Junior Member Join Date: Nov 2007
Member: 622057 Status: Offline Thanks Meter: 0 | THANK YOUThank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Vodafone 125 Restart Problem Solved By Infinity | zeel_zeel | Infinity-Box | 4 | 07-23-2010 08:25 |
>>>> Vodafone 225 Successfully De-blocked <<<< | zeel_zeel | Infinity-Box | 3 | 02-11-2010 03:56 |
vodafone 226fm strange problem | pallumobile | Infinity-Box | 3 | 01-19-2009 20:00 |
vodafone 226fm restart with sim | tajinder | Infinity-Box | 2 | 10-03-2008 10:02 |
vodafone 226fm unlocking problem | abhi1 | Infinity-Box | 5 | 04-30-2008 02:45 |
