12-28-2007, 08:44 | #1 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Motorola C140 Sp-lock Problem AM TRY THIS HANDSET WITH INFINITY BUT RESULT IS................. COM12 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 26 sec Remove/Install battery now ! |
12-28-2007, 08:52 | #2 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | some times show this error COM12 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! Connect Fail Finished, time used: 10 sec Remove/Install battery now ! |
12-28-2007, 11:35 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @SHIJIL_TORNADO I suggest you to read FAQ before ask questions. Answer for your probelm there. http:///vbb/showpo...63&postcount=2 |
12-29-2007, 09:10 | #6 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Yes Am Solved This Problem YES AM SOLVED THIS PROBLEM 6 HANDSET BUT 1 HANDSET AFTER UNLOCKING NOT POWER ON.POWER ON TIME JUST TRUN ON KEYPAD LIGHT ONLY GIVE THIS SOLUTION UNLOCKING DETAILS LOGO HERE AM USE THIS METHODE ] THANK U FOR THE HELP MY DEAR FRINDS AND ALL INFINITY SUPPOTERS |
02-09-2017, 08:37 | #9 (permalink) |
Crazy Poster Join Date: Feb 2005 Location: venezuela-colombia-panama Age: 48
Member: 121598 Status: Offline Sonork: contac via private $ Thanks Meter: 8 | MOTOROLA C122 e2 SP-LOCK PROBLEM AM TRY THIS HANDSET WITH INFINITY BUT RESULT IS................. COM141 [VCP0] selected Action: unlock Device: C122, C123 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 12 sec Remove/Install battery now ! please help !!!!!!!!!!!!!!!! |
02-09-2017, 08:45 | #10 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Press boot key for little longer time. Also check cable/mobile connector. Br. Infinity Box Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
02-09-2017, 15:03 | #12 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
02-11-2017, 15:13 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
lg kp 100 sp lock problem | deepaksawdia | Infinity-Box | 7 | 11-02-2013 09:03 |
Motorola sp lock problem | farihabest | Infinity-Box | 2 | 03-24-2009 13:46 |
G600 SP Lock problem | banditdave | Samsung Flashers, Software, Firmware. | 1 | 01-17-2009 21:36 |
smadel a300 sp lock problem | farhahmed | Chinese Models & Cloned Phones | 1 | 08-16-2008 08:33 |
zte 2010 sp lock problem | jay k sundrani | Infinity-Box | 1 | 09-19-2007 10:57 |
