06-21-2008, 14:02 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Motorola W200 Flash Successfully By Infinity log:- COM6 [VCP0] selected Device: Motorola-W200 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... 115200 Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 reading [Motorola-W200_eeprom]... file saved: C:\Program Files\InfinityBox\QCModule\backup_Motorola-W200_eeprom_20080621-181858.B2E.bin software version: 2.2.08. flex version: FFN_A66_0111_036 LP version: LPH_A66_ASIA2_016 hardware version: MOTOROLA_A66 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active Area: Flex/Customization flash: 8988C400010001:8988C400000000 Write: Flex/Customization Area: Language pack flash: 8988C400010001:8988C400000000 Write: Language pack Write Done Finished, time used: 409 sec Remove/Install battery now ! |
06-23-2008, 12:15 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
06-23-2008, 14:43 | #4 (permalink) | |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
11-24-2008, 16:55 | #6 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 895274 Status: Offline Thanks Meter: 4 | hanks alot .... i have infinity box i write flex to moto w200 sucsessflly ...!!!!!! but when i but cdma sim there isnt network ..!!! it appear no service ... what's wrong ... thanks agin |
11-25-2008, 13:03 | #8 (permalink) |
Member: 895274 Status: Offline Thanks Meter: 4 | Thanks for your reply the phone was restart when it work up... after that the customer give it to maintenance engineer to write software he do that but when he turn on phone well but no service ...!!!! The customer give me the phone and i write all flex in the support area and all not solve the problem and i thenk the phone is locked after write flex ... COM1 [VCP0] selected Device: Motorola-W200 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... 115200 Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 software version: 6.6.25. flex version: FFN_A66_1011_022 LP version: LPH_A66_ASIA1_022 hardware version: MOTOROLA_A66 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active Area: Flex/Customization flash: 8988C400010001:8988C400000000 Write: Flex/Customization Area: Language pack flash: 8988C400010001:8988C400000000 Write: Language pack Write Done Finished, time used: 370 sec Remove/Install battery now ! |
11-25-2008, 13:27 | #10 (permalink) |
Member: 895274 Status: Offline Thanks Meter: 4 | and this is the result when i used 2.2.07_TATA_RUIM flex from support area and the phone be RUIM card Rejected COM1 [VCP0] selected Device: Motorola-W200 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... 115200 Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 software version: 6.6.23. flex version: FFN_A66_1011_022 LP version: LPH_A66_ASIA1_020 hardware version: MOTOROLA_A66 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active Area: Flex/Customization flash: 8988C400010001:8988C400000000 Write: Flex/Customization Area: Language pack flash: 8988C400010001:8988C400000000 Write: Language pack Write Done Finished, time used: 407 sec Remove/Install battery now ! |
11-25-2008, 14:50 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. Flash phone with the next files: w200_Main_6.6.23 w200_Flex_FFN_A66_1011_022 w200_LPH_A66_ASIA1_020_En_Cn 2. repair phone hardware due to it looks like it has problem with RF hardware part |
11-27-2008, 12:47 | #12 (permalink) |
Member: 895274 Status: Offline Thanks Meter: 4 | 1. Flash phone with the next files: w200_Main_6.6.23 w200_Flex_FFN_A66_1011_022 w200_LPH_A66_ASIA1_020_En_Cn 2. repair phone hardware due to it looks like it has problem with RF hardware part Thanks for you .... i try to flash phone as you see the phone work well...but the language is china i used other flex 2.0.10_HGM_RUIM to arabic language the phone now very good thanks agin i want to ask you how i can choose flash to moto c139 ? by infinity box i want to unlock it i do hardware conversion now i want to unlock it and write software ... |
c168 unauthorized phone repaired successfully by infinity! | aikonmani | Infinity-Box | 22 | 06-17-2011 09:33 |
motorola c257 hangup Flash successfully by SCout | kikikokoki | Scout | 0 | 07-09-2009 10:24 |
cdma w200 flash done with infinity | kalpeshoza | Infinity-Box | 3 | 02-07-2009 07:35 |
J100 Unlock Successfully By Infinity. | debmobile | Infinity-Box | 1 | 07-05-2008 09:58 |
n95 SUCCESSFULLY BY INFINITY | .::KHURRAM::. | Infinity-Box | 11 | 09-04-2007 12:58 |
