Motorola W220 unlocking problem Hi guys, I have one Motorola W220 wich i try to unlock but i recieved this: Log opened: [12/29/2006] [11:56:26 AM] App: D:\Program Files\InfinityBox\Moto02\Moto02.exe Loading data, wait... [Infinity Box] v1.31 S/N: XXXX:XXXX Wait... Current model: C168 Done Current model: W220 COM3 selected Model: W220 Action: read unlock codes Phone must be POWERED-ON ! Connecting, wait... Err: connection failed, try again ! Finished COM3 selected Model: W220 Action: read unlock codes Phone must be POWERED-ON ! Connecting, wait... :ñëcâ â ©_ 8³#à imei: D0A0F4B4D0A00000 Err: probably phone not ready, make "Prepare" operation first ! Finished COM3 selected Device: W220 Checking data, wait... Action: Unlock (prepare) Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1120-000 HW ver: SCY-7- Check Flash Done Check Parameters... file saved: Backup_repair_2006-12-29_11-58-59.6AF.bin file saved: Backup_eeprom-2_2006-12-29_11-59-46.6AE.bin Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Make "SP-Unlock" operation now ! Finished, time used: 89 sec Remove/Install battery now ! I would try to flash the phone but i am not shure that this operation is adviced since it seems that theinfinity program reads my phone a lttle ..."wierd" : Connecting, wait... :ñëcâ â ©_ 8³#à imei: D0A0F4B4D0A00000 Flash: 0020:8810FFFFFFFF I need an advice for what should i do in this case, or if someone could tell me that this version is supported or not. Thanks in advance Regards (P.S. i've tryed to unlock and read the phone trough 2 different methods i mean 1. with a normal RS232 interface with slow speed and 2. with infinity-box at different types of speed - the result is the same) |
Completation ( problem solved ) Very strange: I've tryed again but this time i've modified the protocol in the main window from "default" to "protocol v02". this is what i've got: [Infinity Box] v1.31 S/N: XXXX:XXXX Wait... Current model: C168 Done Current model: W220 COM1 selected Model: W220 Action: unlock Phone must be POWERED-ON ! Connecting, wait... S&›¹q©Ìâ â ìS0í] imei: D0A0F4B4D0A00000 Err: probably phone not ready, make "Prepare" operation first ! Finished COM1 selected Device: W220 Checking data, wait... Action: Unlock (prepare) Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1120-000 HW ver: SCY-7- Check Flash Done Check Parameters... file saved: Backup_eeprom-2_2006-12-29_14-44-41.6AE.bin Check Parameters Done Check Space... Flash: 0020:8810 flash: ST M58WR064FT, M36D0R6040T0 T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Make "SP-Unlock" operation now ! Finished, time used: 77 sec Remove/Install battery now ! COM1 selected Model: W220 Action: unlock Phone must be POWERED-ON ! Connecting, wait... Err: connection failed, try again ! Finished COM1 selected Model: W220 Action: unlock Phone must be POWERED-ON ! Connecting, wait... )~vYÆ‚‘â â ’ÀÖܳª¨ imei: 3530020109317012 file saved: Backup_unlock_log_3530020109317012_2006-12-29_14-45-42.6AF.bin Finished And the phone is unlocked... Regards and if someone can explain what is with "prepare" options pls do. Happy New Year |
Hi, "Prepare" is just "Prepare". It's need to read information in Log file and make "Prepare" operation if software ask to make this operation. |
