anil.prajapati | 09-26-2011 16:46 | motorola wx181 unlock error motorola wx181 unlock error Quote:
COM69 [Serial2] selected
module v4.00
Action: read unlock codes
Model: Motorola-WX181
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:5E62:A00C
status: 01
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: MAUI.08A.W08.36.SP1.V28.F1
Version: JRD23_NEP_08A_HW
80 byte(s) read
imei: 35204604123968
connection Ok
193 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 5555
181 byte(s) read
reading data...
warning: wrong packet cs
1898 byte(s) read
warning: unknown lock version: 01000100
error: operation failed !
Finished, time used: 15 sec
Remove/Install battery now !
read flash error Quote:
module v4.00
Device: Motorola-WX181
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 564
provider: M181X-CAALIN1
customization: CM56AC13
customization: XM56AC13
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: disabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000F604485B4
reading: Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__fullflash_part_1_of_1...
warning: wrong cs at 0x0009DC00, retry...
read error recovered
warning: wrong cs at 0x000FD400, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
error: wrong answer: E3
warning: wrong cs at 0x00000000, retry...
aborted by user
error: can not make full backup
file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20110926-211402.B0X.bin
Finished, time used: 1 min 38 sec
Remove/Install battery now ! | |
