03-21-2022, 12:40 | #1 (permalink) |
Junior Member Join Date: Aug 2016 Location: Tunisia
Member: 2605906 Status: Offline Thanks Meter: 11 | huawei jat-l29 cant boot i cant boot it hes dead no power identify Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 54F7BEB96166A241AFBCF05F2C83D2DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9B4482A6C1ED2FF42A682A0E33F4988451F6F121CC544575FD A15311F0B1F318 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v1844 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68433861503E0117496C8227DD EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x01 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 390687874 ( 0x17496C82 ) , MF : 2/2020 EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_mexico.bin EMI : CNT : 001E EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! hw report Operation : HW Report [ v2.34 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 54F7BEB96166A241AFBCF05F2C83D2DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9B4482A6C1ED2FF42A682A0E33F4988451F6F121CC544575FD A15311F0B1F318 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : Huawei : 8A_JAT-XXX | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68433861503E0117496C8227DD EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x01 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 390687874 ( 0x17496C82 ) , MF : 2/2020 EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_mexico.bin EMI : CNT : 001E EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Boot done! Memory Info : CID : 90014A68433861503E0117496C8227DD MEM : VEN : HYNIX | OEM : 4A01 | DEV : hC8aP> DAT : Size: 59640 MB, Max.Speed: 52000 kHz, blklen(512), nblks(122142720), ro(0) EXT_CSD Info : EXT_CSD rev. : v1.8 ( MMC v5.1 ) CSD struct rev. : v1.2 Supported command sets : 1h HPI features : 1h BG operations support : 1h BG operations status : 0h Correct prg. sectors : 0h 1st init time after part. : 1000 ms Min. write perf.(DDR,52MH,8b): 0h Min. read perf. (DDR,52MH,8b): 0h TRIM timeout: 0 ms Secure feature support: 55h Secure erase timeout : 150000 ms Secure trim timeout : 150000 ms Access size : 3584 bytes HC erase unit size : 512 kbytes HC erase timeout : 600 ms HC write prot grp size: 8192 kbytes HC erase grp def. : 0h Reliable write sect count: 1h Sleep current (VCC) : 8h Sleep current (VCCQ): 9h Sleep/awake timeout : 419430400 ns Sector count : 747c000h Min. WR Perf. (52MH,8b): 8ch Min. Read Perf.(52MH,8b): 8ch Min. WR Perf. (26MH,8b,52MH,4b): 46h Min. Read Perf.(26MH,8b,52MH,4b): 46h Min. WR Perf. (26MH,4b): 1eh Min. Read Perf.(26MH,4b): 1eh Power class: 0 Power class(DDR,52MH,3.6V): 0h Power class(DDR,52MH,1.9V): 0h Power class(26MH,3.6V) : 0h Power class(52MH,3.6V) : 0h Power class(26MH,1.9V) : 0h Power class(52MH,1.9V) : 0h Part. switch timing : 1h Out-of-INTR busy timing: ah Card type : 57h Command set : 0h Command set rev.: 0h HS timing : 0h Bus width : 0h Erase memory content : 0h Partition config : 48h Boot partition size : 4096 kbytes Boot information : 7h Boot config protection: 0h Boot bus width : 2h Boot area write prot : 0h User area write prot : 0h FW configuration : 0h RPMB size : 16384 kbytes Write rel. setting : 1fh Write rel. parameter: 15h Start background ops : 0h Enable background ops: 2h H/W reset function : 1h HPI management : 0h Max. enhanced area size : e8fh (30531584 kbytes) Part. support : 7h Part. attribute: 0h Part. setting : 0h General purpose 1 size : 0h (0 kbytes) General purpose 2 size : 0h (0 kbytes) General purpose 3 size : 0h (0 kbytes) General purpose 4 size : 0h (0 kbytes) Enh. user area size : 0h (0 kbytes) Enh. user area start: 0h Bad block mgmt mode: 0h Overall status : MLC status : 0% - 10% used SLC status : Not defined EOL status : Normal ( Less than 80% reserved blocks used ) Done! Elapsed: 00:00:59 |
03-22-2022, 10:38 | #6 (permalink) |
Member: 2605906 Status: Offline Thanks Meter: 11 | Jaydi Operation : Write Flash [ v2.34 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Enabled Safe UserData : Disabled Flash Format : Disabled Files :32 [FL] : Set : preloader_k62v1_64_mexico.bin [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : efuse.img [FL] : Set : cache.img [FL] : Set : recovery_vbmeta.img [FL] : Set : erecovery_vbmeta.img [FL] : Set : vbmeta.img [FL] : Set : lk.bin [FL] : Set : tz.img [FL] : Set : md1rom.img [FL] : Set : recovery_ramdisk.img [FL] : Set : recovery_vendor.img [FL] : Set : erecovery_kernel.img [FL] : Set : erecovery_ramdisk.img [FL] : Set : erecovery_vendor.img [FL] : Set : patch.img [FL] : Set : dtbo.img [FL] : Set : boot.img [FL] : Set : eng_vendor.img [FL] : Set : eng_system.img [FL] : Set : preas.img [FL] : Set : preavs.img [FL] : Set : odm.img [FL] : Set : vendor.img [FL] : Set : cust.img [FL] : Set : product.img [FL] : Set : system.img [FL] : Set : version.img [FL] : Set : preload.img [FL] : Set : userdata.img [FL] : Total size : 0xB8871084 [ 2.88 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 54F7BEB96166A241AFBCF05F2C83D2DE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9B4482A6C1ED2FF42A682A0E33F4988451F6F121CC544575FD A15311F0B1F318 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68433861503E0117496C8227DD EMMC: VEN : HYNIX : OEM : 74 : ID : 68433861503E : PRV : 0x01 EMMC: VEN : HYNIX : hC8aP> EMMC: SNN : 390687874 ( 0x17496C82 ) , MF : 2/2020 EMI : DEV : MT6765 EMI : SRC : preloader_k62v1_64_mexico.bin EMI : CNT : 001E EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484347386134 : VEN : HYNIX | DEV : HCG8a4 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 150100475036424D42 : VEN : SAMSUNG | DEV : GP6BMB : RAM : [ 3.00 GB ] EMI : [08] : eMMC : DDR3 : ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ] EMI : [09] : eMMC : DDR3 : ID : 13014E53304A394137 : VEN : MICRON | DEV : S0J9A7 : RAM : [ 2.00 GB ] EMI : [0A] : eMMC : DDR3 : ID : 13014E53304A394E38 : VEN : MICRON | DEV : S0J9N8 : RAM : [ 4.00 GB ] EMI : [0B] : eMMC : DDR3 : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 3.00 GB ] EMI : [0C] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2.00 GB ] EMI : [0D] : eMMC : DDR3 : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4.00 GB ] EMI : [0E] : eMMC : DDR3 : ID : 150100525036344D42 : VEN : SAMSUNG | DEV : RP64MB : RAM : [ 4.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [10] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [11] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [12] : eMMC : DDR3 : ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ] EMI : [13] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 4.00 GB ] EMI : [14] : eMMC : DDR3 : ID : 150100475036424142 : VEN : SAMSUNG | DEV : GP6BAB : RAM : [ 3.00 GB ] EMI : [15] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3.00 GB ] EMI : [16] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2.00 GB ] EMI : [17] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [18] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [1A] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [1B] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [1C] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [1D] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER DA : SETUP EMI PARAMS FAILED! ERROR : ABORT Error : Fail to init protocol! >>> Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! |
03-22-2022, 10:39 | #7 (permalink) |
