motorola xt1755 cant flash in cm2 give error secure boot how can solve this Card found : S/N : 85B43663 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6735 , Project : wt98736b32_aa1 , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : motorola Device Model : namath Device CPU : MT6737M Device IntName : namath_55 Device Version : 7.0 Device Compile : 22/01/2018 8:51:01 AM Device Project : alps-mp-n0.mp1-V1.0.2_wt6737m.65.n_P109 Device ExtInfo : Moto C Ready to Flash! Scatter Load Ok , BaseBand : MT6735 , Project : wt98736b32_aa1 , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : motorola Device Model : namath Device CPU : MT6737M Device IntName : namath_55 Device Version : 7.0 Device Compile : 22/01/2018 8:51:01 AM Device Project : alps-mp-n0.mp1-V1.0.2_wt6737m.65.n_P109 Device ExtInfo : Moto C Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
use new software bro v2 r4 for secure boot |
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : motorola Device Model : namath Device CPU : MT6737M Device IntName : namath_55 Device Version : 7.0 Device Compile : 22/01/2018 8:51:01 AM Device Project : alps-mp-n0.mp1-V1.0.2_wt6737m.65.n_P109 Device ExtInfo : Moto C Preloader [HW DEV] Info : EMI : DEV : MT6752 EMI : SRC : preloader_wt98736b32_aa1.bin EMI : CNT : 0005 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100464531324D42 : VEN : SAMSUNG | DEV : FE12MB : RAM : [ 1.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 150100464E58324D42 : VEN : SAMSUNG | DEV : FNX2MB : RAM : [ 1.00 GB ] EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 90014A483847346132 : VEN : HYNIX | DEV : H8G4a2 : RAM : [ 1.00 GB ] EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : [04] : eMCP : eMMC+LP/DDR3 , ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :11 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : tz1.img [FL] : Set : tz2.img [FL] : Set : efuse.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xB8D17A82 [ 2.89 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! Operation : Write Flash [ v2.00 r4 ] Repartition : Enabled Flash Verify : Disabled Pre-Erase : Enabled Verify HW/SW : Enabled XData Backup : Disabled Files :11 [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : logo.bin [FL] : Set : secro.img [FL] : Set : tz1.img [FL] : Set : tz2.img [FL] : Set : efuse.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xB8D17A82 [ 2.89 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! |
Hello bro, Pls use DA file from support.... ur problem will be solved |
da i have alredy how to excute that one ? |
Use this addon software for simple method http://forum.gsmhosting.com/vbb/13174409-post133.html place ur da file inside ("boot-collection/ Moto/Xt1755/ Xt1755.bin") and use the addon software set boot function then work with cm2 |
