07-28-2007, 16:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 44
Member: 136052 Status: Offline Thanks Meter: 75 | Mpeg4 GM208 flash erase error 00E20000 my prablem its these im chek "advanced chip detection" and dont chek bat problem remain please help for me thease log ==== log opened: [28.07.2007 19:49:02] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.39 S/N: XXXX:XXXX Wait... Current device: Autodetect Done WARNING ! Settings will be cleared, user data erased, Imei set to default ! Do you want to continue ? COM6 selected Device: Autodetect Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6219:8A01]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp Intel std [def 007Fx010000 0008x002000] 8Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp Intel std [def 0008x002000 007Fx010000] 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp Intel std [def 007Fx010000 0008x002000] 8Mb number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished detecting eeprom area in 2 chip(s)... flash: B000B101000000:B000B100000000 checking area[00000000]: 00000000-007FFFFF... flash: B000B004000000:B000B000000000 checking area[00800000]: 00000000-007FFFFF... eeprom found near: 00C00000 Detected eeprom address is non-standard: 00C00000 If you are not sure that detected address is correct: 1. press "NO" right now 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address[00E00000] ? standard eeprom address confirmed by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 01 eeprom area detected[00800000]: 00600000-007FFFFF reading [eeprom]... file saved: backup_eeprom_20070728-195346.B0E.bin flash: B000B101000000:B000B100000000 Check space Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: B000B004000000:B000B000000000 error: error# 000000A2 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash erase error: 00E20000 error: error# 000000A2 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash erase error: 00E20000 Write Fail Finished, time used: 313 sec Remove/Install battery now ! Is it Beforehand thanked sory my bad english |
07-29-2007, 09:41 | #5 (permalink) |
Member: 136052 Status: Offline Thanks Meter: 75 | have tried 2 programs to repair this ChineseMiracle.exe and MModule.exe This program ChineseMiracle at the beginning initially formatting asks 1) yes or not aim press no 2) yes or not aim press yes afterwards in certain time leaves error: flash erase error: 00E20000 second progamms MModule.exe nonhits asks goes format afterwards leaves - flash erase error: 00E20000 |
6150-id898890 Flash erase error, addr 210000, In=FF Flash=00 | MP | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-29-2002 14:12 |
t28-flash erase error? | Abe | Old Ericsson Phones & Sony Phones | 4 | 02-03-2002 21:35 |
Flash Erasing Error? | hooi76 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-09-2001 04:46 |
6210 3. 04D flash erase error! | qtboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-05-2001 22:38 |
Flash erase error 5110 id 00610061 | jan | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-27-2001 01:50 |
