Old 04-08-2008, 21:38   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
ZTC ZT8380 and autopinfinder
i have a ztc zt 8380 ,
this is my first set after getting my new auto pinfinder ...
when i try to find the pinout of this set with auto pinfinder , i am always getting this error ..
please help me what is the problem ?
==== log opened: [09/04/2008 1:51:29 AM] ====
Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe
Initializing...
software version: 1.07
Smart-Card S/N: ***x
Smart-Card firmware version: 010E
Initializing PinFinder...
Initializing database...
base database version: 01
user database version: 01
Initializing cable list...
Initializing platforms...
Initialization finished
error: can't open COM8
COM2 ready
searching adapter at COM2...
adapter found, version: 2000
Serial No: *********************x
done
Initializing...
done
Cable: 2x6 (L12B)
Power Off !
cable type: 2x6 (L12B)
platform: MT6205, MT6217-MT6228
warning: 2nd answer absent
too many retries
pins: 12, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
too many retries
failed to detect pins
time required: 167 sec
too many retries
too many retries
Power On !
too many retries
too many retries
too many retries
Power On !
Old 04-09-2008, 00:41   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf
Please, see page 19: Automatic pinout detection: Troubleshooting
I hope you can solve at least 99% of possible problems (especially with 8, 12, 14, 15 pins cables) with this instruction.
Old 04-09-2008, 05:50   #3 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i have tried to connect two china mobiles ..
but in both of them i am getting this same error
too many retries ..
i have not opened my infinity box yet ..
Old 04-09-2008, 10:05   #4 (permalink)
Member: 148515
hello!
please run pinout search without cable connected to adapter.
do you getting same error?
Old 04-09-2008, 11:54   #5 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
searching pinout without connecting any mobile to the adapter shows this ..
cable type: 1x8 (L8A)
searching adapter at COM7...
pins: 8, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
time required: 28 sec
Power Off !
Old 04-09-2008, 16:39   #6 (permalink)
Member: 148515
hello!
can you check with which cables you getting search error "error too many retries, warning: 2nd answer absent".
and whith which cables you getting normal end like in post above?
you can select cable type as L5A, to make search faster
Old 04-09-2008, 18:35   #7 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
the phone which i have now is zt8380 in which there is cable type: 2x6 (L12B) connector which i want to connect , and there i am getting this error ..
when i connect the phone ..
what should i do ?
please help ..
Old 04-09-2008, 23:37   #8 (permalink)
Member: 148515
hello!
there could be problem inside you L12B cable.
that is why i asking you to check with other cables (without phone connected)
if they are giving same error or pinout search end normaly ?
Old 04-10-2008, 06:13   #9 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
my connection with the pinfinder is resolved , now i can connect the mobile with it ...
Old 04-10-2008, 06:27   #10 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
this is the log of my cable finding...
platform: MT62xx (autodetect)
searching adapter at COM8...
pins: 12, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
CPU: MT6228
result: Rx:7 Tx:6
time required: 32 sec
Power On !
Old 04-10-2008, 10:17   #11 (permalink)
Member: 148515
hello!
please tell us what was your problem before?
Old 04-10-2008, 18:49   #12 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i connect it to another pc then it was working ...
then when i connect it to the first pc it also worked there ..
i too donno what was the problem ..
i think it is cable or connectivity problem ..
Old 04-12-2008, 20:12   #13 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
sir
i got the problem y i do get this error
too many retries
this error comes when i do use COM PORT 1 or 2 with Infinity ....
i am unable to use COM PORT 1 and 2 with Infinity and auto pin finder .. please help me ..
thanks
Old 04-12-2008, 20:46   #14 (permalink)
Member: 148515
hello!
you must select com port not based on your wish, but basing on windows device manager.
check which com port took your infinity box- this will be your pinfinder com port
Old 04-12-2008, 21:21   #15 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
i want to use com port 1 for a selected program to connect a mobile ..
so i connect the auto pinfinder adapter to the second RJ45 socket in my infinity box and connect the infinity box to the COM PORT 1 of my PC .
will it work ?
Pls, i need pinout for ZTC ZT8380!!! tnx lucsogo Infinity-Box 9 03-16-2008 15:31
Ztc Zt8380 ave_ret HTC & PDA WM( With Touchscreen) 0 02-06-2008 10:46
How to Hard Reset ZTC ZT8380?? lucsogo HTC & PDA WM( With Touchscreen) 0 02-04-2008 00:45
Chinese Phone ZTC ZT8380 davidf Infinity-Box 3 10-21-2007 12:06
Page generated in 0.24110 seconds with 9 queries
