MPEG4 P888 SIMB Hang After Repair Hi, I have a MPEG4 P888, original problem was restarting with or without sim, I found second CPU format safe and them restore imei, but now, second sim had no signal bars and when call comes in to sim b it will not answer, please advise. |
hello! are you sure that you restored Original IMEI? have you touched first phone part? what was both phone parts versions? |
Hi Infinity, Thanks for your response, I checked the imei *#06# before formatting to make sure i have the correct imei and wrote this number back after formatting. I tried to format the first CPU, but it is not formatting in "safe" only in "complete", could this be the problem and if so, how can i solve? |
hello! i would advice to format COMPLETE both phone parts and restore IMEIs. |
Hi Infinity, I'm trying to format COMPLETE the first CPU of this unit, but this is what i'm getting, can you shed some light on this for me: COM10 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #02 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #03 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #04 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #05 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #06 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #07 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 flash: SST SST34HF3244/3284 U 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00300000 Detected eeprom/ffs address is non-standard: 00300000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00380000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: BF7353FFFF0052:18E59F00000000 flash: BF7353FFFF0052:18E59F00000000 Finalization Done Finished, time used: 60 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Hi Infinity, I also tried to write imie to first CPU, but this is what i got: COM10 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono-CPU new imei: 353888000021395 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #02 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #03 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #04 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #05 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #06 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb detecting chip #07 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: BF7353FFFF0052:FFFFFF00000000 flash: SST SST34HF3244/3284 U 4Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00380000 flash: BF7353FFFF0052:FFFFFF00000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00300000 Detected eeprom/ffs address is non-standard: 00300000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00300000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00300000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080828-182340.B0E.bin flash: BF7353FFFF0052:FFFFFF00000000 Backup required data Done Patch required data... 2 step(s) required Patch required data Done Special operation... Special operation Done Write... flash: BF7353FFFF0052:FFFFFF00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 105 sec Remove/Install battery now ! |
hello! both logs are from CPU2. to start work with CPU1 you must switch to other pinout |
Hi Infinity, Thanks for your continued responses and support, i'm a bit confused, so you tell me, for this model, when i run pinfinder, recognises first CPU in 8:4 this is for 6205, the log I sent you. When I disable these pins 8:4 and run pinfinder again it recognises 10:6 and this connects me to 6226, so i assume this one is second CPU and format complete and rewrite imei works perfect here. So, can you tell me where i'm going wrong? |
hello! 6205 is second MCU 6226 is first one. my advice is to format both MCUs and also restore IMEIs in both parts. |
Hi Infinity, I tried formatting CPU 6205 and was not very successful, please see logs above, tell me what elese can i do? |
hello! as i can see- formating pased OK. what about First MCU logs? |
Hi Infinity, I tried to format Mt6205, but now it's telling me "waring: probably flash chip empty,erased, incorrectly flashed or damaged"....i followed the instructions....but still same message |
hello! if program detects flash chip empty,erased, incorrectly flashed or damaged- then problem went too far to solve this by formatings/IMEI resotring. you must flash both phone parts with correct flash files |
Hi Infinity, I've got other handsets in this model that are working fine, please confirm, to get flash file i must proceed to read flash from both cpu and the flash independantly? |
Hello, for dual sim/dual CPU models you need to read flash from CPU1 and then from CPU2 so you will have different firmware (flash files) for each CPU. CPU1 file is bigger, CPU2 file ordinary has less size (less than 50% of CPU1 file). |
