Old 10-14-2009, 06:01   #1 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
Thumbs up more power pinfinder
Hi
how to add more power to pinfinder
i make jumper at box
and add capacitor at end wire but phone can not full power
i need to calibrate touchscreen and write imei
i can find RX and TX easy but need to full power the phone
thanks
Old 10-14-2009, 06:06   #2 (permalink)
Member: 1009679
Thanks Meter: 166
full charge phone battery, attach only ground supply from box to battery terminal make jumper, then put the battery, then make your operation. tested many times!
Old 10-14-2009, 06:14   #3 (permalink)
Member: 1009679
Thanks Meter: 166
i will repeat pinfinder ground supply only should be attached don't include positive supply. put battery in full charge to phone and make operation
Old 10-14-2009, 06:34   #4 (permalink)
Nabil3H's Avatar
Member: 17675
Thanks Meter: 18
Wink
thanks
i will try this and post result
thanks
Old 10-14-2009, 21:49   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i just made small example.
you can use any grounded part to attach crocodile.
or, if you dont have them available- you can use small thin wire taken from battery negatvie terminal
Old 10-15-2009, 03:35   #6 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
you can give supply from external dc supply of 4v.attach supply -ve clip and pinfinder -ve clip to phone -ve pin and ext. supply +ve cliop to phone +ve pin
22-12-2006 New Model Alcatel C635 added. More and more power every day GSMtricks Multi-Box 13 05-02-2007 13:13
08-04-2007 FIRST in the WORLD! New updates comes again! More and more power! GSMtricks Multi-Box 23 04-09-2007 15:52
02-04-2007 Next 3 updates released. More and More POWER every day! GSMtricks Multi-Box 15 04-02-2007 19:27
12-02-2007 Every day more and more power. New Philips Update! GSMtricks Multi-Box 12 02-14-2007 08:50
15-01-2007 New LG models now supported! More and more power every day! GSMtricks Multi-Box 17 01-16-2007 17:04
Page generated in 0.16814 seconds with 10 queries
