mr.infinity supporter i have one phone chaina 1112 i take to when i call after call fail when i try to box safe format after phone bad software show repair bad software option but problem same i going to side pick up this ver after flash phone white lcd ( TOP23_07A_PCB01_GPRS_MT6223P_S00.N1112_V5_53_8m_En _Ru_Fr_Th_Vn_Urdu_Farsi_Ar.B0M ) my phone is software this ver ( TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53__fullf lash_20091013-022502.B0M) plz help me or send me ok file plz i waiting qickly:( |
Bro I also have 1112 chinese but its dead by the user he just flashed with jaf,,,now with which cable should i revive just need pinout bcoz RX, TX not working,,, BR |
u just flash ffs from backup r need good backup from other fone |
flash phone with your own file: TOP23_07A_PCB01_GPRS_MT6223_S00.N1112_V5_53__fullf lash_20091013-022502.B0M Then open phone and check it's hardware. |
brother try to this version software (2.58) chinese miracle try to bad software option your problem slove new version totaly bugs |
wow my problem is slove thx m.anis i try to badsoftware phone is ok perfect thx m.anis |
does old version of Chinse Miracle fixed this problem? |
@all if old version can fix phone but new version can not fix, please, post here operation log for "old" and "new" software so we will be aable to check what is wrong. |
heres another one,maybe its not hardware failure. unit: DX777 mickey mouse history phone locked code to remove only. different baudrate combinations done! ALWAYS WRONG PACKET CS error??? Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: HEXING26_08B_GEMINI_HW Software version: B024-1B_L26_V204" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 353186022472757 imei: 353186022472757 Finished, time used: 5 sec Power off phone now ! COM1 [Serial0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B388:3D26 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 43 sec Remove/Install battery now ! ================================================== ======== FORMATTING COMPLETE MODE COM4 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B388:3D26 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.84, database date: 08.07.2009): HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.B024-1B_L26_V204.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.B024-1B_L26_V204.BIN ver. sw 2: B024-1B_L26_V204, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.B024-1B_L26_V204__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING26_08B_GEMI NI_PCB01_GPRS_MT6226_S01.B024-1B_L26_V204__ffs_20091012-134830.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 300 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ================================================== ====================== COM4 [VCP0] selected module v2.84 Action: touchscreen calibration mode: 1 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B388:3D26 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! ================================================== OM4 [VCP1] selected module v2.84 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:B388:3D26 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! updated : COM4 [VCP1] selected module v2.93 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.B024-1B_L26_V204__fullflash_20091012-124133.B0M.bin loaded error: unknown ffs structure error: can't detect eeprom structure id error: operation failed ! Finished, time used: 12 sec Remove/Install battery now ! back up fullflash http://rapidshare.com/files/29192043...wares.rar.html please pm me,thanks. |
