mt346csoftware need help COM12 [VCP4] selected module v3.26 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: 6253_C85A_SL1_KXD_ML_B_V03 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUIYUE53_09A_PCB01_GPRS_MT6253_S00.6253_C85A_SL1_K XD_ML_B_V03.BIN project-id: 6253_C85A_SL1_KXD_ML_B_V03, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.26, database date: 13.01.2011): HUIYUE53_09A_PCB01_GPRS_MT6253_S00.6253_C85A_SL1_K XD_ML_B_V03.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== Format... error: can not format: 0BC7:S_DA_NOR_ERASE_FAILED warning: can not format: HW_STORAGE_NAND is not present Format... error: can not format: 0BC7:S_DA_NOR_ERASE_FAILED error: last error: 0BC7:S_DA_NOR_ERASE_FAILED Disconnect... done Finished, time used: 1 min 13 sec Remove/Install battery now ! Device: Autodetect 6253 NOR |
Hello, 1. what is the problem with phone ? Are you sure that it's not a hardware fault ? 2. Code: ==================== |
