05-24-2008, 15:57 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | mt6228 format error COM7 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN_D2629EBF].rpl identification#1 detection finished Identification Done Write... formatting... .................................................. ........error: code: 6E00006900 .error: code: 8800006900 .........error: code: 1400006900 ................................error: code: A502000000 error: code: 0600000000 Write Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _27EADFDB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_32 0_7670_HYN_HY128_V2_1.BIN_D2629EBF_20080524-075200.B4X.bin Finished, time used: 99 sec Remove/Install battery now ! |
05-24-2008, 16:02 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Bro try again with Safe formating .. if no success .. than try to find the firmware from support else it would be the processor`s fault.. |
05-24-2008, 16:10 | #3 (permalink) |
Member: 570093 Status: Offline Thanks Meter: 1,067 | thanks bro BHATTI i try safe formay but not connect.if i write firmware on it there is any chance to dead because customer want mobile in same condition if not repair. |
05-24-2008, 16:13 | #4 (permalink) | |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
so ui can have Backup.. and if some thing goes wwrong u can make it to the original condition .. | |
The Following User Says Thank You to .::BHATTI::. For This Useful Post: |
05-24-2008, 17:19 | #5 (permalink) |
Member: 570093 Status: Offline Thanks Meter: 1,067 | i flash it with same flash file on support now set is dead.i check backup file in chinese miracle software but files are only 3kb and not load in software give error.here is log plz help. COM7 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: ADF1801D page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:00F10080001D [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00080000 bytes identification#1 protocol ver: 04 ver. sw1: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN ver. sw2: R888_320_7670_Hyn_Hy128_V2.1, 40619D2D ffs offset/size: 02000000/06000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1.BIN_D2629EBF].rpl identification#1 detection finished security area#1 calculation... Identification Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _27EADFDB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_32 0_7670_HYN_HY128_V2_1.BIN_D2629EBF_20080524-082327.B4X.bin write core area 1 of 3... write core area 2 of 3... write core area 3 of 3... Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _27EADFDB_BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_32 0_7670_HYN_HY128_V2_1.BIN_D2629EBF_20080524-085551.B4X.bin Finished, time used: 2026 sec Remove/Install battery now ! which file is backup file for flashing.because i flash first time for 6228.it has diffrent method for backup.in 6226 backup eeprom for flash and phone is ok.now plz helpp. |
05-24-2008, 18:22 | #6 (permalink) |
Member: 570093 Status: Offline Thanks Meter: 1,067 | first i flash it by: BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_320_7670_HYN _HY128_V2_1__I808_128m_En_Cn.B4M.bin flash complete but mobile dead this is same file as my mobile. second i flash it with:BXWY28_06B_PCB04_GPRS_MT6228_S02.R888_432_668 0_INF_HY128_V2_1__ZTC-ZT8900_En_Cn.B4M.bin but it gives error during flash. |
Help/ Mt6228 format ERROR | IkaMazini | Infinity-Box | 2 | 11-23-2008 13:57 |
Error: Skeys.bin format error? | Alex1234 | DreamBox | 5 | 07-20-2006 09:02 |
D500 Always NAND FORMAT ERROR! phone hanging at startup! sing 3.9.5 soft ver! | ReyTech | NSPRO | 5 | 12-31-2005 13:36 |
3650 Formatting Error | TWISTER_FLasher | Twisterflasher | 25 | 06-24-2004 15:05 |
