MT6571_Qmobile_X2@X6_Factorry File Read Faild_??? http://s11.postimg.org/y5nzbxns3/screenshot_184.png Code: Operation : Read Flash [ v1.32 ] |
Because they are not supported yet. NAND. |
Because it not supported yet for factory fw reading. |
i9500 nand cpu not read Operation : Read Flash [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00C800BC009000550054007F007F0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009C , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet :( Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
All NAND NOT supported for read fw. My previous post say about that it clearly. |
Like MXXXXX |
So, what you leave here, if other tools supported? Use them and be happy , don't waste time with CM2. |
You are free to use any other xxx tool, no one forced you to use Infinity Box/Dongle. When Nand will be supported you can read in News section and here in sticky threads and then use CM2 again. Br. |
ur mxxxxxx tool cant read nand fectory flash .. ask them its possible or not ur mxxxxx tool cant read nand in bin formate also which work perfect with mxxxxx tool or other tool .. try now and urself take working set with NAND chip read file with mxxxxx with any formate bin or scater and try write that file and see what u get in hand :D and after that post in mxxxxx section they will close thread or delet thread ;) PS: ur mxxxxxxx tool totaly depend on cm2 now |
Less users - less problems :D Bye-bye. |
;) Quote:
BEST KAM LOG HONGE KAM PARESHANI HOGI APNI GADI TO CHOTI HAI WBR sahil2000ind |
This NAND BOOT not supported.. [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 Mr. JayDi say here... http://forum.gsmhosting.com/vbb/f296...l#post11307389 Remember.. and no question any more..... Mr. JayDi i trust in you.. keep working for all user of CM2.... |
