04-30-2015, 18:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | MT6575/MT6573 NAND PatternLock reading Code: Operation : Read PatternLock [ v1.19 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 62 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6573 BB_CPU_HW : CA10 BB_CPU_SW : CA01 BB_CPU_SB : CA01 BB_CPU_NM : [MediaTek] MT6573_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x83 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0056 , [HYNIX] HY27UF082G2M [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok! Reading data ... Reading data ... Please, wait Checking ... Get PatternLock ... PatternLock Sequnce : 753698412 Done! Elapsed: 00:02:36 Reconnect Power/Cable! MT6575 , Alcatel OT4007D. No Root , USB Debug and e.t.c. Code: Operation : Read PatternLock [ v1.19 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0085 , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0000 0000 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Reading data ... Please, wait Checking ... Get PatternLock ... PatternLock Sequnce : 753219468 Done! Elapsed: 00:01:48 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to Dzirt For This Useful Post: |
