Old 05-31-2017, 19:24   #1 (permalink)
Member: 1482507
Sonork: 158
Thanks Meter: 11
spd 7731 frp problem .................. what is problem ????
Old 05-31-2017, 19:43   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,421
Originally Posted by MUSTAFIZ View Post
Select Boots one by one,Hold Boot key.
If read device info success all operations will work fine.
The Following User Says Thank You to Kirumira For This Useful Post:
Old 06-01-2017, 00:54   #3 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Can't connect until u press correct boot key ,,, most of mbles have vol+ is boot key hold and connect and try
Sent from my S_plus using Tapatalk
Old 06-01-2017, 05:10   #4 (permalink)
Member: 2082450
Thanks Meter: 1,454
Don't try to format in service mode.
Select correct boot or try one by one ( plane or AltLdr - total 6 boots)
Then do format your phone.
Note: latest driver must be installed from support only.
Use charged battery and connect with correct boot key pressed..
The Following User Says Thank You to chandanps18 For This Useful Post:
Page generated in 0.18357 seconds with 8 queries
