11-05-2017, 16:28 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: Tamil_Nadu Rasipuram
Member: 2185083 Status: Offline Sonork: 100.1670782:dineshras Thanks Meter: 185 | MT6589__samsung__SM-J710F__j73g__6.0__ALPS.JB2.MP.V1.16 firmware need Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734CA03820421B1E3E1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048203CAE1E3B121 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xA82EB19101C49DFC76A36DF2774DC60F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : Galaxy J7 (2016) ProdModel : SM-J710F Device : j73g AndroidVer: 6.0 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.16 MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V14 EXTRA : LCD [0] : ili9885a_qhd_dsi_vdo_boe LCD [1] : ili9885u_qhd_dsi_vdo_boe LCD [2] : #rm67200_qhd_dsi_vdo LCD [3] : hx8394a_hd720_dsi_vdo_tianma LCD Res : 960x540 TOUCH [0] : ft6306_gs CAM [0] : ov5650mipi_raw CAM [1] : ov9760_mipi_raw CAM [2] : ov9762_mipi_raw CAM [3] : gc0309_yuv CAM [4] : sp0a19_yuv CAM [5] : gc2145_yuv CAM [6] : gc2035_mipi_yuv CAM [7] : hi253_yuv MODEM : mbk89_wet_jb2_md1_hspa LOCALE : en_US es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR iw_IL my_MM km_KH fa_IR zh_CN hdpi xhdpi Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
11-09-2017, 15:43 | #4 (permalink) |
No Life Poster Join Date: Aug 2012 Location: MUMBAI-METRO Age: 37
Member: 1800009 Status: Offline Sonork: 100.1654307 Thanks Meter: 806 | hi |
The Following 3 Users Say Thank You to mobite For This Useful Post: |
10-28-2018, 20:20 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A208860487804044 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048608A244408087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x0F4FBB2FE1207DABD2D08419B690F59D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Format/Reset Error! Operation Failed Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A208860487804044 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048608A244408087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x0F4FBB2FE1207DABD2D08419B690F59D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Format/Reset Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A208860487804044 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048608A244408087 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x0F4FBB2FE1207DABD2D08419B690F59D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : j73gxx ProdModel : SM-J700H Device : j73g AndroidVer: 5.1.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.16 SECURITY : IMEI_SW [1] : 358275063462077 IMEI_SW [2] : 358276063462075 BTMAC Addr : 000046662801 WiFi MAC : 000000000000 MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V14 EXTRA : LCD [0] : jd9361_hd720_dsi_vdo LCD [1] : jd9311_hd720_dsi_vdo LCD [2] : rm68200_hd720_dsi_vdo LCD [3] : jd9365_hd720_dsi_vdo LCD [4] : nt35521_hd720_dsi_vdo LCD [5] : fl1281_hd720_dsi_vdo LCD [6] : s6d77a0x62_hd720_dsi_vdo LCD [7] : r61318_hd720_dsi_cmd LCD Res : 1280x720 TOUCH [0] : ft5206 CAM [0] : ov5650mipi_raw CAM [1] : ov9760_mipi_raw CAM [2] : ov9762_mipi_raw CAM [3] : gc2355mipi_raw CAM [4] : gc2145mipi_yuv CAM [5] : gc2035_mipi_yuv CAM [6] : gc0309_yuv CAM [7] : sp0a19_yuv CAM [8] : bf3703_yuv MODEM : mbk89_wet_jb2_md1_hspa LOCALE : en_US es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR iw_IL my_MM km_KH fa_IR zh_CN hdpi xhdpi Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
