12-20-2016, 07:04 | #16 (permalink) | |
Insane Poster Join Date: Mar 2010 Location: indonesia
Member: 1270521 Status: Offline Thanks Meter: 21 | MT6750/55 flashing failed..! Quote:
Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D4207304DD4AB531F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xBB0DAF3C597C55E8CB81212045A3775F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : X9009 ProdModel : X9009 Device : X9009 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : X9009EX_11_A.13_160413 SECURITY : IMEI_SW [1] : 861230032393895 IMEI_SW [2] : 861230032393887 BTMAC Addr : A81B5ADB3DBC WiFi MAC : A81B5ADB3DBC EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1920xM_WIDTH=1080 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : s5k3p3sx_mipi_raw CAM [2] : s5k3p3sp_mipi_raw MODEM : STOM_MODEM=oppo6755_ac0031_lwctg_mp2_umoly Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Read NVRAM [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 59 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41C [eMMC] : FLASH_CID : 150100524331344D4207304DD4AB531F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xBB0DAF3C597C55E8CB81212045A3775F INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok NVM Read Ok, MT6755_eMMC.spnv Done! Elapsed: 00:00:24 Reconnect Power/Cable! | |
The Following User Says Thank You to kumkumhanum For This Useful Post: |
12-30-2016, 19:09 | #21 (permalink) |
Junior Member Join Date: Dec 2008
Member: 924928 Status: Offline Thanks Meter: 30 | Oppo f1s A1601 only vibrate network unlock 100% solution Firmware- https://docs.google.com/uc?id=0Byn45...xport=download Video guide- https://www.youtube.com/watch?v=FxDlvP_YcVc Firm password- yakub&tanu |
The Following 4 Users Say Thank You to alisir For This Useful Post: |
01-19-2017, 18:42 | #23 (permalink) |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | dident work for me i have dumped 4 phones they are four diffrent modeles and all of theme are mt6755 and my phone is mt6750 phone n 1 : MT6755__OPPO__A1601__A1601__5.1__A1601EX_11_A.19_1 61011 2nd phone : MT6755__OPPO__A1601__A1601__5.1__A1601EX_11_A.09_1 60728 3rd phone : MT6755__OPPO__A1601__A1601__5.1__A1601EX_11_A.24_1 61119 4th phone : A1601EX_11_A1601__5.1__A1601EX_11024__201611191742 and i tried every firmware and all pf them give me this error Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_15131 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : OPPO Device Model : A1601 Device CPU : MT6755 Device IntName : A1601 Device Version : 5.1 Device Compile : 19/11/2016 10:27:39 Device Project : A1601EX_11_A.24_161119 Device ExtInfo : A1601 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , V79J3 [eMMC] : FLASH_CID : 13014E51334A3937561002AF3F5D937F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x76A84994B326FBA07EAA7FC5295D9A89 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! ScatCFG : BaseBand : MT6755 , Project : oppo6750_15131 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled M67BL : Check eMMC compatibility M67BL : eMMC supported by BootLoader! Selected forced PMT update Build new PMT ... Update Primary ... Update Mirror ... PMT update Ok! M67BL : Flash Erase Total blocks to Erase : 5 Erase : 0x0000000000008000-0x0000000003F80000 Erase : 0x0000000004088000-0x0000000004000000 Erase : 0x0000000009800000-0x0000000001000000 Erase : 0x000000000AB00000-0x0000000002400000 Erase : 0x000000000D400000-0x00000007397FBE00 Flash Erase Done, time used : 00:00:07 Processing : Writing all Flash Files Flash Partition : PRELOADER Flash PLC Image Flash Ok Flash Partition : RECOVERY Image Flash Failed! Something wrong with files or connection! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following User Says Thank You to AnonDz For This Useful Post: |
01-19-2017, 19:09 | #24 (permalink) |
Member: 2232889 Status: Offline Thanks Meter: 91 | and for the brother that have posted the solution for the mt6750 i appreciate the effort but the firmware doesn't work for all models mine give me error format+download in development mode and the tool have password |
01-24-2017, 19:02 | #25 (permalink) |
Member: 924928 Status: Offline Thanks Meter: 30 | oppo x9009 only vibrate solution |
The Following User Says Thank You to alisir For This Useful Post: |
01-30-2017, 12:06 | #27 (permalink) |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | download this file http://*******/14392091/oppo-a1601f1s Step How to Update OTA zip Firmware to OPPO mobile Download OTA Update and Copy Zip To SD card and Insert In Phone. Reboot Phone In Recovery Mode Using Key Combination. In power off OPPO phone press Hold both Power on and Volume Button From Recovery Click On Install Zip From SDcard and Choose OTA Update Zip Click Yes To Install and Wait Few Minutes To Done and After Follow Screen Options. |
02-02-2017, 11:07 | #29 (permalink) |
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | I also downloaded it the link is working check your browser is OK otherwise change it then open the link Sent from my XT1058 using Tapatalk |
