02-12-2015, 23:39 | #3 (permalink) |
No Life Poster Join Date: Jun 2006 Location: morocco Age: 45
Member: 286812 Status: Offline Thanks Meter: 22 | Operation : Format FileSystem [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582|8312_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0E091611196F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again Boot Error! Elapsed: 00:00:08 Reconnect Power/Cable! after format give me this error help me plz to repair it |
02-13-2015, 05:02 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Hi preloader is erased .It will be supported in next update 6582-6592 First post wat problem phone has? Wat u do with the set using which tool? Plz don't use bootcable or don't press any volume while connecting the set .Check & Post the result Sent from my XT1022 using Tapatalk |
