Old 05-16-2016, 18:46   #1 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
mt8127 read info , read flash all fail
i got mt8127 tab, its model number laser MID-782
it lock with pin code
i was try
1. read info fail
2. read flash failall others are fail.
software hang after DRAM already initialized by Preloader
Operation : Check / Read Info [ v1.47 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BB_CPU_NME : [MediaTek] MT8127_S00
BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8D
NAND Flash : 009800DE009400930076005000080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
[DA_ERROR] : DA Load failed!
ErroCode : 0x2008
DA_LOAD_FAILED
Boot Error!
Operation Failed
Elapsed: 00:07:52
Reconnect Power/Cable!
Old 05-17-2016, 03:38   #2 (permalink)
Member: 1167260
Sonork: 100.1604772
Thanks Meter: 165
its flashing done without any problem with SP flash tool
but touch pad not work
Old 05-17-2016, 06:41   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
CM2 support not all MT8127 NAND phones.
Old 12-07-2017, 04:35   #4 (permalink)
Member: 2774518
Sonork: 100.650600
i need this model.. flash file sir.. pls help me for solution.
Old 12-07-2017, 04:50   #5 (permalink)
Member: 2682716
Thanks Meter: 10
haven't you tried adb reading? tick on miracle maybe it will work
Page generated in 0.36517 seconds with 8 queries
